588,567 active members*
5,087 visitors online*
Results 1 to 4 of 4
    Dec 2003
    673
    Stepped boss and faces?
    Hi, new to SolidCam... I've got a part that will get machined on all sides (this is typical of the parts I make). I read/watched some of the tutorials and got started, and think I know how to do most of it, but in my first op, I'm a bit stuck cutting two stepped portions of the part. Anybody willing to advise or add those features so I can see how its done? (SW2013)
    My thinking of order of ops is:
    OPS1
    Face stock (got that)
    Mill pocket (got that)
    Drill holes (got that)
    Face off the two bosses; top of part and right edge (stuck)
    Profile the outer profile except the arc on right end (holding from the right side)
    WIth the info for the above, I think I know how to finish up the rest (below)
    OPS2
    Flip part over, holding from right side
    Face
    Cut pocket
    Cut end profile (leaving a tab)
    OPS3
    Cut the slots
    Attached Files Attached Files
    May 2011
    33
    Maybe try profiling strategy as per the attached for facing the boss/tabs.
    Dec 2003
    673
    Quote Originally Posted by cncDecoder View Post
    Thanks, I'll check it out!
    Dec 2003
    673
    So it worked fine to just create new geometry (thanks), but theres no way to just treat the part as a projection and cut the outline? Seems silly to have to create new geometry, though that works fine.
    Thx
  1. Machining a offset stepped pin
    By Arich0908 in forum Benchtop Machines
    Last Post: 01-21-2013, 01:23 AM
  2. restricting faces
    By pejaer in forum Tormach Personal CNC Mill
    Last Post: 07-14-2012, 05:22 PM
  3. CAM for multiple faces
    By Woody242 in forum Dolphin CAD/CAM
    Last Post: 02-02-2011, 02:16 AM
  4. looking for a stepped dia soft jaw cutting plug set
    By adamant in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2011, 11:27 PM
  5. stepped topography models
    By lunchtrayrider in forum Rhinocam
    Last Post: 02-19-2010, 09:02 AM
