587,947 active members*
4,076 visitors online*
Results 1 to 4 of 4
    Nov 2003
    93
    Thumbs up stepper 1200 oz from keiling
    did anyone used this motor succesfully to get any decent speed?
    if so what drive did you use and at what voltage..Thanks
    Andy
    Feb 2007
    4553
    Post
    Valmet58,
    I believe 75 to 80 volts would be about average.
    The torque falls off really fast on that motor.
    What is the TPI of your leadscrew?
    See attached PDF
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    What kind of Driver and power supply do you have?
    Feb 2007
    167
    Im running 4 of them, off a keling 20A 75 or 78V (not sure) power supply. Running them on a rack and pinion router were 1 turn of the motor gets me about 3 inches so my rapids are retarded fast - 2000ipm, I have to run Quantum though because starting and stopping an 8ft travel at 2000ipm nearly knocks my machine over from the momentum :P
    Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
  1. Keiling KL-350-48 and G540 hookup Help
    By FandZ in forum Gecko Drives
    Last Post: 11-08-2010, 07:44 PM
  2. A16B-1200
    By bbqa01 in forum Fanuc
    Last Post: 04-12-2009, 06:39 AM
  3. Best 3D CAD/cam options under $1200?
    By jdgoguen in forum Uncategorised CAM Discussion
    Last Post: 03-18-2008, 06:01 PM
  4. laser 1200-60W
    By hkxy in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2006, 01:11 AM
  5. 1200....
    By hardmill in forum Community Club House
    Last Post: 07-12-2003, 09:30 AM
