I have refurbished an Lathe/Mill combination to do the stuff.
Everything fine (EMC2 2.4.2 i maybe upgrade to 2.5 or whatever is needed)
The Heavy Klippfeld K-10B CNC Umbau - tkamsker
Milling head is having some issues where 3 times the Z values are correct then it seems that 0.3mm in steel are to much and the cutting forces are lifting the whole stuff so the real cut is only 0.1mm ,.
My idea now is to add an digital read caliper (i hope the name i correct in english) and feed the value back to the controller. ( I can do electronics so if i need to make an quad signal or whatevery i am fine)
So my idea is that the system tries to go to value Z1 then measures and if needed does Z1+xyz till Z1 wish is measured Z1 or after x tries it gives an error.
So my question i am getting crazy now ? Does it make sense ?
Any better suggestions ?
i think Servos wont help because the transmission is done by Stepper motor belt drive with 1:3 reduction and then it goes to an spindle which again transmits the power to an ratio. So thats why i want to measure (and be able to use it in manual use )
thanks
in advance
thomas
