Picked up a CNC Mill. It's a Grizzly G0704 conversion. I switched out the board on it because it had the smooth stepper setup for Mach 3.
I have a C41 Variable Speed Control board, and Kelling KL-5056D controllers for X, Y, and Z.
I switched out to a CNC4PC C10 board and got rid of the smoothstepper because I would rather have LinuxCNC.
Here's what I've got wired on the C10:
__________________________________________________ _________________________________
17 UNUSED
GND UNUSED
16 "DIR", C41
14 "PWM", C41
GND "GND", C41
(16/14/GND ABOVE TO INPUT ON C41 BOARD)
1 UNUSED
2 "DIR-", X CONT KL-5056D
COM UNUSED
3 "PUL-", X CONT KL-5056D
4 "DIR-", Y CONT KL-5056D
COM UNUSED
5 "PUL-", Y CONT KL-5056D
6 "DIR-", Z CONT KL-5056D
COM UNUSED
7 "PUL-", Z CONT KL-5056D
8 UNUSED
COM UNUSED
9 UNUSED
10 "BLACK" ON E-STOP
5VOLT "RED" ON E-STOP
11 "GND", C41
5VOLT "5 VOLT", C41
(11, 5 VOLT ABOVE TO POWER ON C41 BOARD)
12 "#2 ON DB9 CONNECTOR"- RED ON X LIMIT SWITCH AT MILL
5VOLT "#5 ON DB9 CONNECTOR"
13 "#3 ON DB9 CONNECTOR"- RED ON Y LIMIT SWITCH AT MILL
5VOLT "#1 ON DB9 CONNECTOR"- BLACK X/Y/Z ON LIMIT SWITCHES
15 "#4 ON DB9 CONNECTOR"- RED ON Z LIMIT SWITCH AT MILL
5VOLT "RED", ALL + ON CONT KL-5056D'S
EN UNUSED
5VOLT "RED", 5 VOLT A/C POWER
GND "BLACK", GND A/C POWER
(ABOVE 5 VOLT/GND FROM A/C POWER ADAPTER)
***PIN 6 ON DB9 TO GROUND ON PWM BOARD***(AT THE MILL THIS GOES TO A SMALL TERMINAL IN THE BOTTOM RIGHT OF THE ELECTRICAL BOARD FOR THE MILL. THERE'S A SMALL "F-" NEXT TO THIS TERMINAL?***
***PIN 7 ON DB9 TO NORMALLY OPEN ON RELAY 2 OF PWM***(AT THE MILL THIS GOES TO THE TRANSFORMER INSIDE THE ELECTRICAL BOX ON THE MILL!!)***
__________________________________________________ _______________________________________
So I need to know is this wiring setup should work ok?
And if so, I need to go through the step config wizard.
I've figured out that my driver timing settings are:
Step Time- 1200NS
Step Space- 1200NS
Direction Hold- 5000NS
Direction Setup- 5000NS
I'm assuming that I would select single paralell port with this?
When I go to the PARA PORT 1 SETUP it automatically assigns "ESTOP OUT" to Pin1. Should I move the wire from Pin 10 to Pin 1 for this?
I'm new to all of this, so I apologize for the stupid questions. I just want to get this mill working finally. I'm comfortable with the operation side of this thing, but the wiring and hardware side is a bit of a loss to me.
