Stepper driver board
Hi guys
I'm part way though a small CNC project that I started so I could learn a bit more about the process. I've played with computers, lathes and mills over the years so now I want to learn to combine them. I joined the Perth Artifactory as I don't have a home work shop, the guys here are good but I like to get info from a range of sources before I filter this and see what makes sence to me.
Hi all
I started to build my version of a 3D printer, I got side tracked while using the CNC router to cut some of the pieces for my printer... I've now decided to make it into a light duty router so I can learn the procee before I start on a full size version.
Can anyone recomend a cheap simple driver setup that runs from USB? I'll be using vcarve generated files and Mach3. I'm ok with the hardware side of things but could do with a bit of help selecting the right electronics...
I have this post on another forum on this site with no replies so I've posted it here as well. Too many forums to chose from.....
I'm sure there will be many more questions so thanks in advance.
Dave
