587,374 active members*
3,494 visitors online*
Results 1 to 8 of 8
    Nov 2006
    10
    Stepper motor drivers ?
    I am designing a circuit board to control 4 unipolar stepper motors. I planned on using the Allegro 5804 but they are obsolete. I have looked into some of their newer chips but can’t find much info or application notes. I want this board to drive any motor from 9 volts to 24 volts or more and at least 1 amp. What unipolar stepper motor driver chips do you guys like and where can I find info and application notes for them?
    Meanwhile I am looking into a couple chips mentioned on this forum.
    Jul 2005
    28
    Unipolar stepper motor driver
    The Allegro SLA7062M is a nice unipolar driver chip that I have used.
    The datasheet can be found here: www.techkits.com/SLA7062M.pdf
    Page 11 of the datasheet shows applications information. The chip can drive up to 3 Amps and will operate in half-step, quarter-step, eigth-step or sixteenth-step (microstepping) modes. It accepts simple step & direction signals so it will work fine with any parallel port breakout board.
    -Ed
    Nov 2006
    10
    Thanks Ed
    Do you know where I can find any sample application circuits that I can use as a starting point?
    That sense circuit wants an 0.1 to 2 ohm resistor. The only resistors I see at Digikey in that range are 5 watt. ???? It's only a sense input and 4 5 watt resistors take up a lot of real estate.
    I am a digital kind of guy and not an engineer.
    If I could find example circuits, I could adjust them to fit my needs.
    Sep 2006
    509
    Check out www.hobbycnc.com website - his "old" design uses the SLA7062M chip.
    I bought one of the 4 motor controllers and it works well for me (a mechanical guy - definitely not electronically oriented!)
    Nov 2006
    10
    Thanks ninefinger
    I saved that one for future reference. His prices are great but he didn’t divulge any secrets.
    Jul 2005
    28
    SLA7062 Resistors
    Clyde,
    The sense resistors carry the motor current which can be a maximum of 3 Amps.
    I use 0.3 Ohm, 3 Watt resistors. (Power dissipation = I*I*R) 3 x 3 x 0.3 = 2.7 Watts. So 3 Watt resistors are minimum, 5 Watt resistors will be even better.
    Mouser Electronics carries 0.3 Ohm, 3 Watt resistors.
    I understand the real estate issue, so I mount my resistors vertically.
    You can see a photo of my board here: http://www.techkits.com/industrial/index.htm
    -Ed
    Nov 2006
    10
    Thanks Ed
    That helps a lot. Somehow I didn't think they would do that. I assumed (hehehe) that the sense pins would just be a reference.
    Nice board!
    Jun 2003
    3312
    Might find some help at my website:
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
