588,385 active members*
5,106 visitors online*
Results 1 to 8 of 8
    May 2003
    6
    stepper motor help
    could some one help me .
    I have 3 step motors mod # c6838-9212k-c5
    2-phase 1.8 DRG step
    DC2.57v 2.8A
    VEXTA
    would these work for home built CNC
    mill if so what volts /amps/and so on should I run them at.
    Thanks much
    muzleldr
    Mar 2003
    2139
    Those are nice motors. 4 wires or 6? What driver board do you plan to use?
    We can answer a little better once we know those details.
    Eric
    I wish it wouldn't crash.
    May 2003
    6
    4 wires I dont no what driver board to use
    thanks muzleldr
    Mar 2003
    2139
    I would use this board http://www.xylotex.com/#3axis
    You would need to keep the current under 2.5 amps, but the is a current pot to do just that on the board. I would use a 24 volt or more powersupply.
    I am not sure of the torque of those motors but I am sure they are 150 oz+
    They will be perfect for a home made router. How large a machine are you planning?
    Eric
    May 2003
    6
    I was thinking of about 2'x4' mill.
    mabe geco driver board because of
    $ geco build your self kit .
    all help and info welcom!
    thank you
    muzleldr
    Mar 2003
    2139
    With the gecko's you need 3, one for each motor. They handle the current no problem at 7 amps each.
    Eric
    May 2003
    6
    is that 7 amps good/bad
    I thought I saw a geco drive for 3or4 axis.
    lI am still in the planing stage but I have the stepers and did't know if thay would work.
    muzleldr
    Mar 2003
    2139
    If you are refering to these drives, www.geckdrive.com then no, you need one for each motor. yes 7 amps is good.
    If you are building your first machine, I would stick to the cheaper xylotex board. It should be fine for those motors. You may want to doublecheck with them to be sure.
    Also, start a little smaller for your first machine...say 2' x 2' or even less (I would recommend no larger than 2' x 1'). There are plenty of challenges in building a cnc router without the added complexity of a larger machine. Trust me...I know...
    Eric
  1. Mixing servo and stepper
    By ty1295 in forum Servo Motors / Drives
    Last Post: 01-19-2005, 04:26 PM
  2. Attaching a Stepper
    By andy_ck87028 in forum DIY CNC Router Table Machines
    Last Post: 12-24-2004, 06:09 PM
  3. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
