603,960 active members*
2,310 visitors online*
    Mar 2008
    3
    stepper motor selection
    Hey, I'm brand new. I enjoy the building, mechanical aspects, but I'm not sure on a whole bunch of things. First post is- How do you know how much holding torque you need for your x,y, z axis motors? I'm hand building out of assorted scrap. Is there a good method of testing your lead screws and telling how much torque you need? And how are these motors rated amps work out when you have a chopper drive and run them at higher voltage? My board is only good for 2.5 amps max (maybe). If I need more torque than the motors can supply, can I get gear reductions to help the motor out? And how does that screw up the software trying to drive that motor? I am building on less than shoestring budget. Thanks,Dextron
    Sep 2007
    740
    go to the geckodrive.com site and download stepper101 pdf file. It will explain a lot.
    Mar 2008
    3
    re stepper
    Bob, Thanks for the info. I'll check it out. Dextron
  1. X2 Stepper Motor Selection
    By dleroi in forum Benchtop Machines
    Last Post: 09-18-2007, 05:56 AM
  2. Motor selection help?
    By Ben Colby in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2007, 09:07 PM
  3. Stepper Motor Selection
    By dberndt in forum Stepper Motors / Drives
    Last Post: 12-06-2004, 01:50 PM
  4. Motor selection advise needed? Servo or Stepper
    By Beezer in forum DIY CNC Router Table Machines
    Last Post: 03-21-2004, 07:24 PM
  5. Motor selection
    By Konstantin in forum DIY CNC Router Table Machines
    Last Post: 03-14-2004, 07:08 AM
