603,958 active members*
2,403 visitors online*
Results 1 to 4 of 4
    Feb 2006
    24
    Unhappy Stepper motor spec?
    I have MAE stepper motor HY200-2240-290 and cant find any specs
    it sais 2.9A per phase 1.6 ohm, how do i find voltage, can i use any voltage within reason as long as amps are adhered to?
    Mar 2003
    35494
    Voltage = amps x ohms, or 4.64Volts. For best performance run them at 10-20 times the rated voltage, or 48V -90V. Provided your drives can handle the voltage. And yes, do not exceed the rated current.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2006
    24
    thanks gerry
    i knew it was something simple...
    whats the point in supplying such outrageously higher voltage than motor spec?
    Mar 2003
    35494
    Torque drops off rapidly as rpm's increase. Increasing the voltage lets the current flow through the motor faster, maintaining more torque as rpm's increase. Generally, useable speed is proportional to voltage. If you double the voltage, you can roughly double the useable rpm you'll get out of the motor.
    Gerry
  1. Need Stepper spec/wire help
    By PoppaBear10 in forum Stepper Motors / Drives
    Last Post: 10-12-2006, 03:07 AM
  2. NEMA motor frame spec
    By damae in forum Mechanical Calculations/Engineering Design
    Last Post: 01-19-2006, 08:27 AM
  3. Hooray got motor spec sheet
    By eat in forum Servo Motors / Drives
    Last Post: 10-03-2005, 10:49 PM
  4. Need to know the spec. of this stepper
    By CrazyRonny in forum CNC Machine Related Electronics
    Last Post: 05-27-2004, 04:28 AM
  5. Stepper motor spec' source & question
    By Damachine in forum DIY CNC Router Table Machines
    Last Post: 04-06-2004, 07:01 PM
