587,801 active members*
3,493 visitors online*
Results 1 to 6 of 6
    Mar 2004
    500
    Stepper Motor Wiring
    I have bought 3 motors and I haven't found any information on which wire is which so far. They are 8 wire Unipolar Bipolar motors. How can I find out which ones are ground and step and direction? For unipolar what are all of the wire possibilities. Eg. Ground, Step Dir, Step Dir, for one motor?
    Thanks.
    Mar 2003
    234
    Hi Sanghera,
    Me again. If you have 8 wire motors then take a look at this: http://www.xylotex.com/PacSciIB.pdf
    By the way, you are using a Xylotex board right?
    Marv
    Apr 2004
    24
    Hi Sanghera,
    I have some wiring diagrams for the Pacsci Powermax II, octagonal case motors motors to the site's gallery. The wiring concept is the same for all 8 wire motors. They may be useful to you.
    Bipolar series wiring for pacsci
    Bipolar parallel wiring for pacsci
    Unipolar wiring for pacsci
    The color codes and shield drains relate to the particular wire I use in the cables that I make. Be sure to not be misled by the color of the outputs, just 'follow the lines' to build with your own cable.
    Jason
    Mar 2004
    106
    Maybe this link could help you, it's a complete tutorial about stepper.
    http://www.cs.uiowa.edu/~jones/step/index.html
    I have see another simple tutorial to determine what cable does what on your stepper but I could not find it.... I will search and let you know if I find it.
    Good luck
    CrazyRonny
    Apr 2004
    39
    Stepperworld.com also has a simple tutorial that may help:
    http://209.41.165.153/stepper/Tutorials/UniTutor.htm
    You can use an Ohm meter to find the center legs and then go from there.
    Good Luck
    Jul 2003
    246
    Possible configurations with 8 wire step motors
    http://www.cnczone.com/gallery/data/500/1242coklu.jpg
  1. Attaching a Stepper
    By andy_ck87028 in forum DIY CNC Router Table Machines
    Last Post: 12-24-2004, 06:09 PM
  2. Not good for a stepper motor?
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 12-02-2004, 06:31 AM
  3. Stepper motor spec' source & question
    By Damachine in forum DIY CNC Router Table Machines
    Last Post: 04-06-2004, 07:01 PM
  4. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  5. disassembly of stepper motors
    By dhprc2 in forum CNC Machine Related Electronics
    Last Post: 06-26-2003, 01:09 AM
