588,638 active members*
5,188 visitors online*
Results 1 to 13 of 13
    Stepper Motors
    I am either going blind or have totally overlooked it because I cannot find in the Building the KRMx01 book what type, size, etc. the stepper motors are.
    Any help? Any one?
    Sep 2006
    6463
    Re: Stepper Motors
    Hi, go browse EBAY.....most of the stepper motor suppliers also have a chart showing the dimensions of their stepper products.
    Ian.
    Re: Stepper Motors
    Seriously? You present the same problem I find in the book. I can browse "Ebay" all day long, but that doesn't help when I don't know what to get. I could get a 76oz motor, 40oz motor, dual shaft, Nema 17, Nema 23, etc. etc.
    I need to know what was used to build the KRMx01 so I keep things the same and RIGHT. Why would you even tell me to go to ebay and not tell me the stepper motor I need for the KRMx01 CNC?
    Somebody with the knowledge of what I need please help......
    Sep 2006
    6463
    Re: Stepper Motors
    Sorry I poked my nose in........your problem is not my problem.
    Jun 2013
    1041
    Re: Stepper Motors
    4-Axis DIY Nema 23 Electronics Kit | CNCRouterParts
    This is the electronics kit used for that machine.
    Ben
    Re: Stepper Motors
    Thank you very much! Now, one other question... I bought the 1/2-10 Five start Acme screws and clamps. These are 1/2" diameter. The stepper motors in the kit will have 3/8" shafts. I believe either I'll have to sleeve the stepper motor shafts? Or have someone with a metal lathe cut the end diameter down on the screws?
    Can you confirm what is the best route?
    Feb 2015
    Re: Stepper Motors
    The instructions call for the 380 oz 1/4" shaft motors. You also need the 1/2" to 1/4" couplers to attach the motors to the lead screws.
    Dave
    Re: Stepper Motors
    Do you by chance have a part number for the couplers and a place to acquire them?
    Thanks!
    Re: Stepper Motors
    Nevermind on the couplers, I found them where I got the motor kit. Thanks!
    Feb 2015
    Re: Stepper Motors
    You can get them from cncrouterparts.com. Here is the link:
    Oldham Zero Backlash Couplers | CNCRouterParts
    Mar 2006
    115
    Re: Stepper Motors
    If you are using the anti-backlash nuts from cncrouterparts, you will need to modify your build slightly because they are not a direct replacement for the original nut. You can see what I done to correct it plus some drawings and other info by visiting this link.
    Additionally, here is a photo showing the mod.
    Mar 2006
    115
    Re: Stepper Motors
    Sorry Michael. I didn't realize you already posted this information.
    Joe
    Aug 2010
    686
    Re: Stepper Motors
    No problem, the more its posted the easier it can be found.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
  1. 20 stepper motors + 9 normal motors
    By Yaro in forum For Sale Only
    Last Post: 08-08-2014, 09:57 AM
  2. Stepper motors or ac servo motors?
    By JIM at ATG in forum Commercial CNC Wood Routers
    Last Post: 06-13-2011, 09:10 PM
  3. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  4. Wanted DIY stepper driver circuit for 6 wire stepper motors
    By Colin300 in forum Australia, New Zealand Club House
    Last Post: 09-21-2007, 03:20 AM
  5. stepper motors or servo motors?
    By jprobst in forum Torchmate
    Last Post: 07-13-2007, 11:37 PM
