588,287 active members*
4,703 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > stepper motors won't turn (setup worked in the past)
    Mar 2015
    Hi everybody.
    I have a problems with all motors from a plasma cnc table. In the old workshop plasma cnc table and motors were turning without any problems. After being disassembled and reassembled in another workshop we have encountered a every strange problem. Steppers won;t turn when jogging from mach3 software.
    We have change the cable and for the new setup he have used cat6 double shielded cable. We are using 2 breakout board: one for motor control, enable command, X,Y,Z limit switch and one for controlling the ARC on, and thc control. Both breakout board seems to be working. I can enable disable steppers, limit switch are working (input ports form the first breakout board) and I see when i manually switch the limit switches. Sending enable comand is done using output pin 14 for the first BB, Z motor connected to 4,5 pins, X motor to 67 pins, and Y to 8 and 9 pins.
    Motors are locking when I apply power to them, I can get them to unlock when I go Estop, But when I jog i can se the X,Y,Z value modifying in the mach GUI, but the motors are still. I have replace : a) breakout board, stepper driver, lpt cable, motor, change the lpt port. We have used a software that monitors the lpt output and it seams that for mach3 outputs correctly to the lpt port.
    I really do not know how to proceed next and what to check. It could be the cable I have used but then I have test it using a motor connected directly to the driver and we have the same result. and strange is that all motors X, Y and Z haves the same issue.
    If anybody has any idea how to debug this it would be great.
    Jan 2005
    1695
    Re: stepper motors won't turn (setup worked in the past)
    Which driver do you have?
    Is the Enable pin properly asserted?
    Do you have a photo of your setup?
  1. Replies: 8
    Last Post: 11-02-2014, 02:49 PM
  2. stepper motors will not turn
    By markymark1 in forum Stepper Motors / Drives
    Last Post: 03-21-2013, 05:18 PM
  3. stepper motors turn off
    By gaffa in forum CNC Machine Related Electronics
    Last Post: 03-15-2009, 03:07 PM
  4. how turn stepper motors off when not in use in Mach 3?
    By uplb in forum Mach Software (ArtSoft software)
    Last Post: 01-01-2009, 03:24 PM
  5. stepper motors turn only one direction
    By Mike Boarman in forum CNC Machine Related Electronics
    Last Post: 11-24-2006, 11:43 PM
