![Quote](images/misc/quote_icon.png)
Originally Posted by
Rotax91
Thanks guys!! I appreciate the effort. I will pick the one that can get it to me the fastest. I don't think I would have hurt anything since the port is pretty much made up of I/O and not voltage transmission.
Looking at the pinout in the g540 manual, looks like the step/direction lines are in 1-9 which on the cable I was using, are not connected.
When the servo is at idle/ unit is powered on. Do the steppers make a high frequency noise? I describe it like the noise that old tube televisions made. Also, the shaft is tight. Can't turn it by hand when power is applied. Normal?
Thanks again.
