588,546 active members*
5,374 visitors online*
Results 1 to 5 of 5
    Mar 2009
    stepper power supply?
    I know you can use 10-20x voltage on a stepper motor; but if the motor uses 1.2A and say I'm using 3 motors, does the power supply need to be 1.2A or 3x1.2A - 3.6ish.
    Jan 2007
    146
    Quote Originally Posted by eon View Post
    I have read here on the zone that you only need 2/3rds of the total rated amps of the motors for a power supply. Total motor rated amps times .67 = total PSU amps.
    Read the attachment in post #6 here:
    http://www.cnczone.com/forums/showthread.php?t=68715
    you can of course oversize the power supply without any problems.
    Mar 2003
    35538
    Depends on what drive's your using.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2007
    300
    Also, the 10-20x the motor voltage is a old rule of thumb developed back when round stepper motors were the standard. I talked with a engineer at Gecko drives a while back and learned this. There is a simple formula for maximum voltage which multiplies the motor inductance by a constant which is better suited to todays square hybrid stepper motors. The formula is in the instruction sheet for a G201 drive and can be had at Gecko's website.
    Mar 2008
    3655
    Hi eon. Welcome to the Zone!
    Best Power Stepper Voltage formula: 32 times the square root of inductance in mH.
    Power supply Amperage formula: Total motor Amps times .67.
    UNLESS you are running dual slaved steppers on one router axis. In THAT case, you should size PSU for total Amps.
    CR.
  1. Power supply for my stepper motors
    By tmcp in forum Stepper Motors / Drives
    Last Post: 01-21-2009, 05:07 AM
  2. Power supply for stepper motor
    By gaga2410 in forum Stepper Motors / Drives
    Last Post: 11-09-2007, 12:42 AM
  3. help on stepper motor power supply
    By ahmed in forum Stepper Motors / Drives
    Last Post: 06-14-2005, 05:56 PM
  4. stepper power supply problem
    By bertvk in forum CNC Machine Related Electronics
    Last Post: 08-20-2004, 07:08 PM
