603,965 active members*
2,613 visitors online*
Results 1 to 6 of 6
    Apr 2005
    85
    Stepper Question
    Hi All,
    This is my first post so I hope I've submitted to the right forum. I have a question about some stepper motors. I bought three Astrosyn Minebea 23LM-C373-01 6 wire stepper motors. The statistics are 12 v/phase, 0.44 A/ phase 1.8 Degrees/step. I am looking for a driver board that will work well with these steppers. I contacted Xylotex (sp?) regarding their 4-axis Unipolar board and was told that I would get poor performance as far as top speed and torque are concerned due to a high impedance (The motors are rated at 27 OHM). The response confused me... does that mean these are just poor motors for CNC use? Should I use a Bipolar driver instead? Any and all help is much appreciated.
    Jan 2005
    1695
    Unfortunately, the motors are no good. The main problem is the high voltage required to make them perform. Bipolar won't make a difference . You need a driver that can run from as high of voltage as possible (expensive). Your best bet is to get different motors.
    Jan 2005
    746
    Look for a motor that has a low voltage rating and a high amp rating, more amps equals more torque. You generally supply the motor with a voltage that will be 10 to 25 times the name plate rating on the motor, this will give you your speed and the amps will do the work for you. That is why you see drives with high voltage ratings.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Nov 2004
    131
    I use the picstep driver with 24V 500mA steppers. It's great for the small mill i'm building, but it ain't fast. I also use 30V supply for now.
    by the way you can find more about picstep at http://www.fromorbit.com
    Jul 2003
    246
    Jerber
    What is the range of IPM If we use 24V 500mA step motor for small cnc?
    Nov 2004
    131
    Using a M10 metric lead screw and 1/8 microstepping, I get around 340 mm/min as max speed. I only played around with the Mach2 demo though. But I don't think other software will make much difference.
  1. Stepper Motor Question
    By Dman in forum Servo Motors / Drives
    Last Post: 01-16-2005, 04:55 AM
  2. Stepper drive question
    By Dman in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 03:55 AM
  3. Stepper Motor Question
    By bcromwell in forum CNC Machine Related Electronics
    Last Post: 08-31-2004, 08:42 PM
  4. Stepper motor spec' source & question
    By Damachine in forum DIY CNC Router Table Machines
    Last Post: 04-06-2004, 07:01 PM
  5. AC stepper motor question
    By flybynight in forum CNC Machine Related Electronics
    Last Post: 01-21-2004, 12:47 AM
