603,780 active members*
3,787 visitors online*
    Feb 2010
    27
    stepper ratings
    I have a couple of motors.
    both are 23 size.
    Both have 4 wires
    Motor #1
    3.5v /phase
    1 amp /phase
    Minebea branded
    Motor #2
    5.4v /phase
    1.5 amp /phase
    Vexta Branded
    I am new at this. So I now trying to work out how they will preform and how hard I can drive them.
    This should then allow me to choose a suitable controller.
    Jul 2008
    411
    Are there no part # on the motors?
    At a guess these are fairly low torque i.e. typically 1 - 1.4Nm (141 - 200oz-in) as a 1A - 1.5A NEMA23 motor suggests an older design - most now are 2.1A or more.
    Being 4-wire means these are probably internally wired for bipolar series connection, so these are not going to be speed freaks...
    Without part numbers only some inspired guesswork is possible:
    Minebea make custom steppers so you may not find an exact match but their current catalog would suggest a 1A/3.5v (=3.5ohm winding) bipolar would be around 0.8Nm (110oz-in).
    Vexta don't currently offer a 4-wire motor rated at 1.5A, but the rough equivalent from an older catalog is 1.4Nm (200oz-in).
    Both of these are likely to be relatively high-inductance, 8-12mH/phase due to the series windings.
    If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
    Feb 2010
    27
    Sorry for the long delay in responding
    Motor #1
    3.5v /phase
    1 amp /phase
    Minebea branded
    Part Number Mineba 23LM-K202-p2
    I would like to know what voltage I should start playing with.
    I got these pretty cheap so am happy to use them to learn with before I biuld the router.
    I am also thinking of building "egg Bot" and these steppers should meet the challenge.
  1. Keling stepper ratings
    By MechanoMan in forum Stepper Motors / Drives
    Last Post: 04-12-2009, 03:20 PM
  2. Stepper motor: voltage vs. current ratings
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 09-08-2008, 06:14 PM
  3. Current ratings on stepper motors
    By yoopertool in forum Stepper Motors / Drives
    Last Post: 06-10-2007, 11:25 PM
  4. Stepper motor power ratings?
    By decoder in forum Stepper Motors / Drives
    Last Post: 04-17-2007, 12:24 AM
  5. Stepper motor ratings
    By thomasholley in forum Stepper Motors / Drives
    Last Post: 07-08-2004, 04:45 PM
