Mandala Rose Works, LLC is proud to announce our Stepper Relocation Kit for the Tormach 6" Rotary table. This kit allows you to relocate your stepper motor behind the table, instead of off to the side, by replacing the direct drive method of operating the table, with a pulley and belt system. The design of our relocation kit provides stability to the drive shaft of the rotary table so that your rotary table's bushings won't get damaged by side pressure.
Due to the size and compact nature of the Tormach mills, sometimes a few of the accessories can have trouble interacting with each other. This is why we have developed the Stepper Relocation kit for the standard rotary table.
Mounting of the 4th axis on the left of the mill table works fine, until you decide you want an Automatic Tool Changer (ATC). The stock configuration of the rotary table allows it to be mounted only on the left side of the table of the mill. The Stepper Relocation kit by Mandala Rose Works, LLC, allows you to mount the rotary table on the right side of the mill, thereby eliminating all interactions with the ATC.
The installation of the relocation kit takes about 10 minutes and involves NO SOFTWARE CHANGES to Mach3.
This kit works with both the 1100 and the 770 and is currently designed for the 6 inch rotary table. A kit is in development for the 8" rotary table and will be released in the next few months.
If you are building your own 4th axis unit, the relocation kit could also be a good start to your project!
Product details, photos and pricing can be found on Mandala Rose Works - 4th Axis Stepper Relocation Kit for Tormach 6 inch rotary table
Thanks for reading!
Wade
Attachment 223068
