603,383 active members*
3,827 visitors online*
    Mar 2003
    93
    Stepper vs servo on system 100
    On the system 100 (4' x 8'), what is the diference in price between servo's and steppers. Whats the difference in speed ?
    Feb 2007
    972
    The upgrade to servo is $1000. On the servo system we use double cable chains to keep the encoder cables and power cables separated. We use size 34 servo's with 1000 line encoders (4000 cnt/turn quadrature).
    The stepper can cut at about 300 in/min and the servo is about double that.
    One big advantage of the servo would be in drilling because Z axis raise and drop is so fast, while a stepper is much slower lifting and dropping a router.
    Cut quality is the same for stepper and servo cutting at the same speed.
    There are limit switches on all axes as well.
  1. Type of servo system?
    By toninlg in forum Servo Motors / Drives
    Last Post: 02-22-2007, 09:42 PM
  2. need help to adjust servo system
    By webcruiser8 in forum Employment Opportunity
    Last Post: 11-27-2006, 09:36 PM
  3. Stepper and Servo on same system?
    By Enzo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-08-2006, 06:02 PM
  4. Servo System Set Up
    By Gorillakilla in forum Servo Motors / Drives
    Last Post: 11-15-2005, 11:04 PM
  5. Servo System SYS-3A released
    By imserv in forum News Announcements
    Last Post: 09-05-2005, 05:42 PM
