587,798 active members*
3,379 visitors online*
Hybrid View
    Dec 2014
    Question stepper will not enable
    Guys, I am stuck and need your help.
    I have a Kstep/Kflop combination and want to drive 4 wire NEMA 24 stepper motors.
    5V and 48V are connected to Kstep, diode D1 and D2 confirm the connected power.
    Software runs, drivers are installed, Kflop is communicating with the software KMotion 4.32. (yes, I updated the firmware of the Kflop).
    The stepper motor is connected to channel 0.
    All good so far, except that I can't enable the motor. D3 (enable status) stays off.
    In the console I can send "EnableAxis0" and it is confirmed with "Ready". I can send "Enabled0" and it confirms with "1". However, D3 stays off.
    I tried to use "KStep/InitKStep3Axis.c" as an initialisation file without success.
    I also checked all jumbers. Current and voltage limits are correctly set. External 5V is selected and supplied. JP30 (Disable Opto) was tried with and without jumper.JP34/35 (Isolation) are both set. Nothing seems to get hot.
    I could not find anything on the internet that did the trick for me. I am thankful for any suggestions / help.
    Hank
    Henner
    Dec 2014
    Re: stepper will not enable
    Problem is solved.
    I did the following three steps, however, not sure which one actually did the trick.
    1) I switched back to the older KMotion 4.31.
    2) put back the older firmware 4.31
    3) selected Output Channel 8 for the stepper motor on Channel 0. (Honestly I have no idea why it is not Channel 0.)
    Anyway, it seems to work now, except the BodePlot. ...
    May 2006
    4052
    Hi Hank,
    The enable on KSTEP is controlled by KFLOP IO bit 45. It needs to be set as an Output and Set High to enable KSTEP.
    See the section on "Enable KSTEP Amplifiers" here:
    Using KStep
    "KStep/InitKStep3Axis.c" is written to watch for motion and to enable KSTEP when there is motion. Then after a few seconds of no motion KSTEP is disabled.
    Please return to Version 4.32
    The OutputChan number also needs to be set to 8 as KSTEP requires the Step/Dir signals to be driven as LVTTL signals.
    Regards
    TK
    http://dynomotion.com
  1. Enable/disable
    By willheg in forum LinuxCNC (formerly EMC2)
    Last Post: 06-08-2012, 02:35 PM
  2. How do i enable LPT3
    By GUIDOSAN in forum Machines running Mach Software
    Last Post: 04-07-2012, 04:22 PM
  3. Enable voltages on M1 pin 1
    By dodgy74 in forum CNC Machine Related Electronics
    Last Post: 01-04-2010, 10:35 PM
  4. Enable how????
    By mjhooo8 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-13-2008, 07:27 AM
  5. Connecting Amp Enable
    By keithorr in forum CamSoft Products
    Last Post: 03-22-2005, 12:31 AM
