I'm starting to see the appeal in a CNC milling machine... :stickpoke
Hoping to draw on other people's experiences on what might be a well trodden path - what stepper motors are a good choice to go with the full ballscrew cnc fusion kit #4 conversion of the X2 mini mill?
http://www.cncfusion.com/minimill1.html
http://www.cncfusion.com/images/X2mo...0pics/kit4.jpg
The cnc fusion ballscrews are 5 tpi aren't they?
If I went ahead with the plan, I'd want to install a counterweight for the z-axis, removing the spring loaded arm from the left side of the X2.
I think the Keling KL23H2100-35-4B steppers rated at 381 oz-in might be a good choice for the X & Y axis. Question is, would the same also suffice for the Z axis, bearing in mind that the cnc fusion kit is direct drive (1:1) on all the axis, including the Z axis ballscrew?
http://www.kelinginc.net/NEMA23Motor.html
http://www.kelinginc.net/KL23H2100-35-4B.pdf
Also curious to hear what speed of rapids I could expect from this (on all axis)? I mean fully reliable rapids off course, no missed steps!
If so then should be able to make use of a Gecko 4-axis G540 driver and keep things simple.
http://www.geckodrive.com/product.aspx?c=3&i=14469
I've been reading alot of threads about X2 conversions and there seem to be many variations for driving the various axis - leadscrews, ballscrews, direct drive, pulleys, etc. With the linear motion mechanics nailed down I'd just like some advice on the remaining variables...
Thanks for any advice!![]()
