588,212 active members*
4,322 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > Steppers Stalling, Microstepping & Acceleration/Velocity
Results 1 to 5 of 5
    Feb 2004
    95
    I'm having issues setting up my machine and I'm getting frustrated. Here is my machine specs:
    4 Axis CNC Stepper Motor TA8435H - from here ebay
    3-260 OzIn 4-Wire Stepper Motors from Probotix
    14 pitch lead screws at 1:1 gear ratio
    30V Power supply
    1/8 micro-stepping
    I followed the instructions that came with the driver board but I have never been able to find out how to calculate the acceleration/velocity or find a value that works for my machine. When I job it around the motors with stop and make a loud buzzing noise which I assume the are stalling. Are they trying to go too fast, not enough power or something else causing that. They aren't binding or anything.
    Also, not sure what to set the micro-stepping at on my driver board. Is that affecting the stalling? My machine is no precision instrument so not sure really what the micro-stepping is but I assume it makes it more precise or takes more steps.
    Any help would be appreciated
    Mar 2003
    35538
    You won't get much speed with a 14 tpi leadscrew. Probably about 30ipm max.
    What are your accel and velocity settings?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Feb 2004
    95
    I haven't fired up my machine in a while and I think my pc is disconnected. I'll try and get it fired up tomorrow and get those values. Not really looking for a lot of speed just want it smooth and reliable. Got to get rid of it stalling.
    Mar 2003
    35538
    It could also be a resonance issue. Does it sound like mine in this video?
    http://www.cnczone.com/forums/showpo...&postcount=180
    Gerry
    Feb 2004
    95
    No doesn't sound like that, I'll record it tomorrow. The motor stops and makes a buzzing sound like it is trying to move but can't, seems to only happen when going fast jog. Slow jog doesn't do it.
  1. Acceleration and Velocity vs stalling.
    By Drools in forum DIY CNC Router Table Machines
    Last Post: 03-18-2010, 02:15 AM
  2. Max Velocity and acceleration
    By Jamy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-04-2008, 06:35 AM
  3. Taig velocity/acceleration
    By juzwuz in forum Taig Mills / Lathes
    Last Post: 02-12-2007, 09:38 PM
  4. Velocity/Acceleration question
    By studysession in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2007, 11:01 PM
  5. Fine Tuning Velocity and Acceleration.
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 09-30-2006, 07:46 AM
