603,832 active members*
4,678 visitors online*
Thread: Steps
    Aug 2007
    115
    Steps
    I recently converted a 7x14 lathe, funds or lack there of has forced me to use the stock screws.
    I'm using a automationtechnologiesinc.com 2 axis setup.
    My Z axis seems to be working fine, the problem I'm seeing is on the X axis, which has a 1mm pitch screw.
    I set up the stepper controller for the least number of steps, in this case 400 per rev, multiply that by 25.4 (I'm using inch mode) to get 10160 for my steps per
    If I run a wizard and create the gcode for a facing cut, things come out close (off by .003)
    If I change the jogging mode so I can step at .001 and use a test indicator(mitutoyo) it only steps .0005-ish
    If I double the steps per setting it then steps .001 but when I run a program it's way off .2 or more
    another fun thing is the backlash settings, If I set it at .001" the motor spins but it doesn't start moving, if I put it to .002" it jumps .005"!
    writing it down starts to make me think it might be a stepper driver issue, but they seem to work other wise - I'll try changing the step settings maybe that will help.
    any ideas or suggestions would be greatly appreciated
    Aug 2007
    115
    seems I was a bit optimistic about how accurate the cuts where when running a program, seems the deeper I cut the farther off it was, which makes sense.
    Changed the steps per on the controller - made no difference
    I'm going to try turning off the sherline half pulse setting that the docs I pulled down said should be on - can't hurt at this point
  1. IH steps per
    By Runner4404spd in forum Charter Oak Automation Support Forum
    Last Post: 10-25-2010, 02:34 PM
  2. Where Do The Steps Go ????
    By Gads in forum DIY CNC Router Table Machines
    Last Post: 02-01-2009, 04:09 PM
  3. 51,200 steps?
    By dondeaida in forum Stepper Motors / Drives
    Last Post: 05-26-2007, 12:15 PM
  4. Steps
    By Cartierusm in forum Uncategorised CAM Discussion
    Last Post: 04-24-2007, 06:33 PM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
