587,744 active members*
3,252 visitors online*
Thread: Stirlings?
Page 1 of 2 12
Results 1 to 20 of 34
    Apr 2006
    12
    Stirlings?
    I get that Stirlings aren't IC engines but for lack of a more appropriate place...anyone building them?
    Aug 2005
    48
    Right, Stirlings are not IC
    You are right, Stirlings are not IC (Internal Combustion) since the heatsource is outside the engine it selves. Neither are they to put into the category of steam engines since they don't invoke a phase change vapor <> liquid. If to be categorized I would put them among “hot air engines”, sealed devices that work trough the Carnough cycle without having the media (air, helium, whatever) to go trough a phase shift (liquid <> gas).
    But I guess that cnczone isn’t the right forum for this. Try Model Engineer.
    Best regards from Sweden, the country of the midnight sun
    /jan
    Jul 2003
    1220
    Are the CNCZONE rules really that narrow?
    I would think that the Stirling Engine would be of interest on this forum.
    May 2006
    2420
    Interesting read, never heard of the Stirling Engine until now, still a little confused on how it works, little too late at night for me right now...
    As for someone building one, I would like to give it a go, I just have to finish my 3 axis router first, oh yeah and get through the house building process, then probably a boat shed, but after that I'll get straight on it.
    Interesting how they make such good cooling units under outside power.
    Thanks for something to add to the "to do" list.
    Russell.
    Mar 2004
    261
    If you use CAD to design and CNC machines to cut the parts, why wouldn't this site be an appropriate place to discuss Stirling engine builds? Just add a new forum for threads..... Anyone interested in discussing how to make one?
    RipperSoftware
    Oct 2003
    175
    http://www.bekkoame.ne.jp/~khirata/english/make.htm
    heres a site for building a simple one out of a can ..... i haven;t built one yet myself the guy that got me started in the machining built one you could set it on your hand and it would run from the heat of your hand
    Jun 2003
    3312
    A Sterling Engine is a temperature differential engine that rely's on a closed system of gas. It's motive force comes from expansion and contraction of the gas. Even though the Sterling cycle has been around for a LONG time, it's not been much more than a novelity even though there have been some very powerfull Sterlings built. Part of my leasure reading over the last year has been on producing electricity and if it was feasable for me to build something to generate power in a suburban setting. It' isn't real feasable for a DIY'er to build photovoltiac cells, I live in a region that wind isn't real practicle, so in looking for other possibilities, a Sterling engine(s) might be the most practicle for me. Utilizing the Sun's IR heating, and the earths underground 53 degree constant as temperature differential sources. Still reading and thinking though. There is a lot of interest across the world on Sterlings as an energy source. And when you consider that depending on where you live relative to the equator, on sunny days, there is nearly a kilowatt of IR energy per square meter from the sun, seems like we should be harnessing more of it to produce motive energy.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jun 2003
    3312
    http://www.emachineshop.com/engine/ has a simple rotary sterling
    Mar 2005
    1136
    Here's a link that shows how they work - simply two pistons, 90 degrees apart. the displacement piston alternately moves the air from a hot space to a cold one, power comes from the expansion and contraction of the air.
    http://www.keveney.com/Stirling.html
    They are low power/low efficiency and can therefor be a pain to get a model running properly. you have to hit that optimal balance of the piston sealing well enough to take advantage of the pressure changes, but have minimal drag/friction because its so low power. While low power, their advantage was that they did not the danger and complexity of steam (because there's no boiler) here's some pics of one i made, a 1/4 scale model. this particular one is water pump, using the water it pumps as the cooling force via a water jacket around the upper half of this cylinder. it runs on camp stove fuel and pumps water beautifully, but only after a lot of fine fitting and bore lapping (with homemade adjustable copper laps)
    Attached Thumbnails Attached Thumbnails piston assembly.jpg   Mcgyvers Rider Ericsson.jpg   close up Rider Ericsson.jpg   replicating antique draincock.jpg
    Aug 2005
    48
    Sorry
    Quote Originally Posted by Kiwi
    Sorry if I stepped on someone’s toes - not my intention. Promise :-)
    What I was thinking of was that I have seen forums and pages dedicated to Stirlings. One of my friends built one after getting hints from such a page a few years ago. Rather simple they are and some types can be built with material easily machined by simple cnc’s, materials like aluminums and plastics
    :cheers:
    /jan
    Jul 2003
    1220
    jan
    They don't have to be simple.
    A NZ company is making them for generating electicity.
    http://www.whispergen.com/
    Also one of the Scandinavian countries are using them to drive submarines. (I believe they are very hard to detect with sound equipment.)
    Aug 2005
    48
    jan
    They sure don't need to be simple. Our Swedish navy use them in their submarines and those engines are very complex, but the original sterling engine is very simple as is e.g. the more complex "kalorik" engine by John Ericsson" (the guy with the propeller an who also build the "Monitor". I also once found an hot air engine in an American history book. The engine was put to the market i guess around year 1850 with the advertised by Cammeyer and Sayer as "An engine simpler than a stove" or something like that. A simple device it was and it was a "Stirling clone". You can make them complex if you want. I like nice engineering, but I also admire simplicity. For a beginer it would be more simple to start with a "simple" Stiling than an IC engine.
    /jan
    May 2006
    138
    Hello,
    I am currently designing a simple stirling engine and will post up some pics soon. Not sure where I'll put them but probably in here! If they get removed, so-be-it but I'm sure it'll be of some interest to somebody.
    In the past I've only made model steam engines but want to try a stirling engine before I attempt an IC engine.
    Nick
    Mar 2003
    2139
    A great idea. I am working on adding a Stirling Engines section to the forums...Won't be long.
    Eric
    I wish it wouldn't crash.
    May 2006
    2420
    Send those pics Nick, I for one am quite interested in seeing a working engine, but I must resist the temptation to have a go myself, I found I get more achieved if I limit myself to 100 unfinished projects at a time... once I get my router made then that will be a different story, can't have only 99 things going at once hehe
    I get the theory of the engine now but still find it hard to believe it actually works
    Russell.
    May 2006
    138
    I know what you mean, I still have a problem seeing how the air is cooled and heated so fast! What's even more baffling is the low temperature differential ones, they only need a delta T of a few degrees to work.
    I have to confess to actually buying one of these from e-bay, just to get an idea of dimensions used etc. It works from the heat absorbed from your hand.
    The first one I am going to attempt though, will hopefully run off a tea light. I presume it will be easier to get a hot air engine to run if it's got a bigger temperature differential.
    No doubt we will soon find out!
    Good idea Eric to add a Stirling section, there are whole societies for Stirling engines and I'm sure people will find it interesting.
    Nick
  17. #17
    Apr 2006
    12
    I'm glad there is interest. I for one am certainly interested, obviously since i posted =)
    I have found these forums as a whole to be full of useful information and even more packed with interesting, helpful members. I am also quite glad to hear about a new subforum being created for the Stirling, thanks Eric!
  18. #18
    Jun 2003
    3312
    If you start running though Sterlings and heat differential engines, there are some amazing configurations. The one thing that has me stumped, I kind of thought there would be some references to utilizing R134 or R22, ammonia, etc for gas, and thus helping the heat/cool cycle.
    "Liquid ammonia boils at any temperature greater than -28°F and will expand to 850 times its liquid volume. One gallon of liquid will expand to 850 gallons or 113 cubic feet of gas."
    Look up "icy ball".......
  19. #19
    Jul 2005
    12177
    Quote Originally Posted by pminmo
    Did you not find anything about using helium. I seem to remember reading something a long time ago about the idea of using helium because it has a high heat conductivity so the gas can cool and warm quicker.
  20. #20
    Aug 2005
    48
    Quote Originally Posted by Geof
    You are right about helium and it is used in the most efficient Stirlings. Helium is also a very small gas molecule that has a low mass and moves very fast. The other heavier gases mentioned in the beginning of this line of the thread (like the coolant media in refrigerators) are less suitable in a Stirling engine. They have a high weight and change easily phase and might be better of(???) in a sealed steam engine. By the way, I experimented with propane in a low temperature sealed steam engine… let’s say that that experiment will not go any further… and please all of you, avoid such adventures.
    /jan
Page 1 of 2 12
