603,348 active members*
2,758 visitors online*
IndustryArena Forum > CAM Software > Mastercam > STL TO SOLID OR SURFACE
    Nov 2009
    7
    Hi. I am using Mastercam X 10.2mr2. I am pretty good with solid modeling but have never made a model with threads...not sure how. I need to make a lathe model with o.d threads so I was wondering if after verifying and then saving as an stl file is there some way to convert this to surface or solid so I can shade and make prints with. Any help would be great.
    Oct 2008
    45
    Quote Originally Posted by grand master x View Post
    Well your new best friend is….. turn profiles or Silhouette boundary don’t know if X10 had it in menus or if they are still in the Chooks.
    good luck!
    Apr 2003
    3578
    you can not really make a solid there was a C-hook a while back I have to check my archives for it or the Mastercam forum FTP that would take the stl file and change ti surfaces. but if I were to make the thread with the solid I would create the helix and then the profile of the pitch and Solids sweep to create the tread.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. from solid to surface
    By nabil_elbadri in forum Solidworks
    Last Post: 04-29-2009, 07:07 PM
  2. solid surface cnc choice
    By EvanB in forum Commercial CNC Wood Routers
    Last Post: 04-08-2007, 03:12 PM
  3. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
