587,852 active members*
3,497 visitors online*
IndustryArena Forum > CAM Software > Mastercam > .stl surface machining question
Results 1 to 4 of 4
Hybrid View
    Dec 2009
    8
    I have a project I am trying to do. I am using bender bmp and I want to import the stl file into mastercam and machine the part in mastercam but I am having problems on how to do it.
    I am running mastercam 9.1 I also use solidworks. I tried saving the .stl file in solidworks and then using the solid but it will not save it as a parasolid. any help would be appreciated. thanks.
    Where are you getting the stl from? do they have a model? The model is the best thing to track down if this is not available. In toolpath, click surface before you choose rough or finish you will have a menu come up in the menu CAD FILE will be on N turn this to Y turn SURFACE to N pick your rough or finish toolpath you would like to use fill in the toolpath options when you say done it will prompt you for the stl file to use.
    Hope this helps.
    Steve Arteman
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Dec 2009
    8
    I am getting the .stl file from the bender bmp program.
    Dec 2009
    8
    thanks a bunch that worked.
  1. Arrow500 slow surface machining
    By cncwork in forum Cincinnati CNC
    Last Post: 09-16-2009, 02:08 AM
  2. machining angle for surface rough pocket for MC9
    By Chuck Reamer in forum Mastercam
    Last Post: 08-31-2007, 12:39 PM
  3. Surface machining advice
    By Julian M in forum Mastercam
    Last Post: 01-26-2007, 09:19 PM
  4. surface machining + xilog
    By Shawnm in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-18-2006, 02:55 AM
  5. edgecam bug in machining text onto surface
    By sanjayb in forum EdgeCam
    Last Post: 06-14-2006, 12:01 AM
