587,698 active members*
3,199 visitors online*
Results 1 to 7 of 7
Hybrid View
    Jun 2006
    247
    stock profiles
    I'm having a lot of trouble getting stock profiles to work
    below is a profile I'm trying to get to work
    the geometry was opened from an autocad file
    I know all the intersections are clean, I trimmed them in both autocad and in edgecam
    Even when I completely re-created the geometry within edgecam, the profile would ignore some of the lines and cut off corners of the stock
    Mar 2006
    1013
    Yep, It'll do that.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Oct 2003
    127
    here is how i have got around this problem before.
    since this is a simple shape it won't be hard to work around.
    first don't try to make this one piece of stock.
    make it 5 different pieces of stock consisting of 5 rectangles that overlap.
    make each ear a seperate rectangle and use profile to make all 5 individual pieces on the same layer at the same time (1 block at a time) and that should work for you when you go to manufacturing.
    i'm not sure what controls this but i assume it's got something to do with tolerance settings internally in the stock creation somehow.
    i have used this method for odd shapes before and it worked for me.
    good luck hope that helps.
    Jun 2006
    247
    thanks guys
    I figured out another work-around too
    I re-created the profile in autocad using a poly-line instead.
    When I imported that geometry, it worked like its supposed to
    Jul 2005
    Selecting entities by chaining
    When Edgecam prompts you to "Digitise points on profile", use the chaining method to select the entities (don't window select). To chain the entities, double-click (using left mouse button) on any entity to select all connected entities. The chaining method is taught in my Basic Edgecam training class. Curt Long, http://www.pceaze.com
    Curt Long
    Mar 2006
    1013
    Hey Curt. Welcome to the forum.
    Mike Mattera
    May 2004
    142
    ...NO..SORRY ..THERE ARE TIMES THAT CHAIN SELECT DOES NOT WORK FOR SHAPES LIKE THIS (USUALLY DOES BUT EVERY NOW AND AGAIN...) SELECT EACH LINE ONE AT A TIME ON THE SAME END OF EACH LINE.. SO IF YOU ARE SELECTING A LINE THAT IS RUNNING EXACTLY HORIZONTAL (LEFT AND RIGHT) THEN PICK THE LINE ON THE SIDE OF THE DIRECTION THAT YOU INTEND TO TRAVEL..... AND ALWAYS SELECT IN ORDER..NOT RANDOMLY..
    THIS TOOK ME A WHILE TO LEARN..GOOD LUCK!
    DONT MIND MY SPELLING ... IM JUST A MASHINIST
  1. Z-Profiles
    By mrcodewiz in forum Dolphin CAD/CAM
    Last Post: 05-17-2008, 01:22 AM
  2. Rail profiles?
    By sp1nm0nkey in forum Linear and Rotary Motion
    Last Post: 02-04-2008, 07:11 PM
  3. plasma profiles
    By trevorhinze in forum Waterjet General Topics
    Last Post: 01-24-2006, 06:14 PM
  4. Profiles for CNC lathe
    By Don C in forum Mini Lathe
    Last Post: 04-25-2005, 01:17 AM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
