603,946 active members*
2,633 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Stock Setup, is it Required?
    May 2009
    1447
    When I do a contour toolpath in McX5, there a place to setup your stock (size and depth).
    Is this step required to finish a cut or it is just a visual indication to alert you during verifying the toolpath that your stock is smaller than the toolpath?
    I always do the stock setup but as a beginner I would like to know its purpose
    Thank you
    Nicolas
    Dec 2008
    3216
    Re: Stock Setup, is it Required?
    No... stock is not needed to create a toolpath
    BUT.... may be needed for the more advanced toolpath ops like clearing around a solid.
    Here is a good example.... a basic wireframe "Facing" operation does not require geometry, but would generate a path if you had defined "Stock" (you select no geometry), it's the only one that's different that I know of.
    Query... I noticed on other posts that you might be using advanced ops with solids instead of using wireframe geometry
    Eg a door with a circle cut out for the lock... this can be done by drawing a rectangle for the door and a circle for the lock, you don't have to create a solid.
    Ie. using lines & arcs to define your part and apply the paths too.
    May 2009
    1447
    Thank you Superman, always best answers
    Nicolas
  1. STOCK SETUP
    By mousongie in forum Mastercam
    Last Post: 02-01-2014, 11:41 AM
  2. Stock Setup
    By kolias in forum Mastercam
    Last Post: 01-21-2014, 01:31 AM
  3. Stock Setup Issue with X5
    By stephenj5 in forum Mastercam
    Last Post: 06-21-2012, 12:44 PM
  4. Replies: 2
    Last Post: 12-06-2008, 03:10 AM
  5. stock setup
    By Goran P. in forum Mastercam
    Last Post: 12-27-2006, 04:18 PM
