Sometimes when you put in a fresh insert you get chatter because the new cutting edge is so sharp. Was the previous insert that did not chatter used before you started this job?
A possible fix is to stone the sharp edge of the insert to put the most minuscule chamfer on; a couple of swipes with an oilstone might do it. The idea is to take of the extremely sharp edge without dulling the tool and destroying its cutting ability.
