603,545 active members*
2,357 visitors online*
IndustryArena Forum > CAM Software > Vectric > Strange Pocket Toolpath Problem...
    Hello all, long term reader - first time poster.
    I can set up 2 cuts in vcarve pro:
    a) an outside profile cut of a 50mmx50mm square to 8mm deep
    b) a pocket cut of a 50x50mm at 8mm deep
    The outside cut cuts perfectly in X and Y directions. The pocket cut is out (too small) by 0.5mm in both X and Y directions
    I've tried different tools, different materials. I though it might be an error on my callipers so have bought another set and still every pocket toolpath I cut is out by the same amount. I thought it might be slop in the rack and pinions but pretty sure I've eliminated that. I suspected a spindle bearing error but why error is only on pocket cuts? Tried climb/conventional. nothing.
    I am completely baffled. What am I missing?
    The code is
    Code:
    T1M6
    G17
    G0Z24.010
    G0X0.000Y0.000S10000M3
    G0X133.286Y50.285Z24.000
    G1Z19.000F6000.0
    G1X135.286Z18.200
    G1Y52.285Z17.400
    G1X133.286Z16.600
    G1Y50.285Z15.800
    G1X135.286Z15.000
    G1X133.286Z14.200
    G1Y52.285Z13.400
    G1X135.286Z12.600
    G1Y50.285Z11.800
    G1X133.286Z11.000
    G1X135.286F8000.0
    Y52.285
    X133.286
    Y50.285
    G1X130.286Y47.285
    G1X138.286
    Y55.285
    X130.286
    Y47.285
    G1X127.286Y44.285
    G1X141.286
    Y58.285
    X127.286
    Y44.285
    G1X124.286Y41.285
    G1X144.286
    Y61.285
    X124.286
    Y41.285
    G1X121.286Y38.285
    G1X147.286
    Y64.285
    X121.286
    Y38.285
    G1X118.286Y35.285
    G1X150.286
    Y67.285
    X118.286
    Y35.285
    G1X115.286Y32.285
    G1X153.286
    Y70.285
    X115.286
    Y32.285
    G1X112.286Y29.285
    G1X156.286
    Y73.285
    X112.286
    Y29.285
    G0Z24.000
    G0Z24.010
    G0X0.000Y0.000
    M30
    Re: Strange Pocket Toolpath Problem...
    This might be silly but I just want to cover all our bases. In your pocket toolpath settings you should see a small box with the option to add "Pocket Allowance". There will be a box where you can enter a value. If your pocket vector is drawn to exactly 50mmx50mm then this value should be 0.0mm.
  1. Stepper motors strange toolpath generated
    By ssjantonio in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-08-2017, 10:43 AM
  2. Very Strange Toolpath..hopefully someone can tell me what this machine is doing...
    By strangetanks in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-17-2016, 08:46 PM
  3. missing pocket toolpath
    By newnew005 in forum PhotoVCarve and VCarve Pro
    Last Post: 05-29-2014, 05:23 PM
  4. Strange toolpath trying to cut hex - V25
    By TonyW in forum BobCad-Cam
    Last Post: 03-24-2014, 11:16 PM
  5. Pocket Toolpath
    By jcnewbie in forum Mastercam
    Last Post: 10-21-2009, 07:16 AM
