Hope someone can help as Syil customer support does not exist (I think they need to be told what the word means !)
Have a nice shiny C6 CNC lathe all ready to go. Problem is it came with a very simple pamphlet for the manual version and no other documentation, and there is nothing useful on the Syil website.
Ok, it is not exactly rocket science connecting the C6 to the control box and plugging a parallel cable between the box and computer. (BTW I have the speed sensor plugged into the Y ref socket - but have tried it in the A ref socket as well)
The problem is I have loaded the C6 profile from the Syil website into Mach 3 on the PC, but nothing I do on the Mach 3 makes the C6 do anything.
I turn on the mill, then the control box, then the PC. Once the PC has booted up, I get the following lights on the control box:
A Z Y X
Running (green) ON off off off
Direction (red) ON ON ON ON
Limit switch (green) off ON ON ON
I load up Mach3Turn - no change in the lights.
I try to jog the x & z axis etc and although things happen in the software, I get nothing from the mill. No satisfying clicks, movement, or anything. And no change in the control lights.
When I press the limit switches, the corresponding light on the control box goes out - but that's it.
I have the power switch set to the right (2) as that makes the control box come on. If I turn it to the left (1), the green lights next to it comes on and I can manually start the spindle - but the control box does not light up. (This is where an instruction manual would come in very handy - SYIL !)
I hope someone can help me - am I doing something stupid or is something faulty? I have tried to get help from Syil - but have heard nothing from them.
