603,939 active members*
1,755 visitors online*
Results 1 to 6 of 6
    Mar 2006
    3
    Strange results when zeroing z axis
    Hi, I have searched for this in the forums but found nothing. I have noticed that when I manually "zero" the z axis on my Mach 3/Taig machine (using the software button on the main Mach screen), sometimes the x and Y axis jumps to some other value. What happens is that I carefully reference my x and y axis for the project I am working on, then later I move the tool outside of the area I have already milled so I can change tips and re-reference the z axis to the top of the material block I am working on. When I do this and touch the z axis to zero it, the x and y axis SOMETIMES changes. Not all the time, just often enough that I know I didn't imagine it! I also noticed similar behaviour when I loaded a new G-code file after carefully referencing the x, y, and z axes. My references change.
    Any help appreciated...
    Mar 2003
    35494
    How much do they change by?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    4826
    Are you seeing the X or Y motors actually jump when you rehome Z? Or does the axis display reset for all three axis?
    Have you tried returning all three axis to home? Jog off somewhere in all three axis and then return to home a few times, to see how repeatable the machine is.
    If your program uses G92, this could cause a problem with the home position changing whenever the axis are positioned in a random location. This would most likely be a really gross error, though.
    First you get good, then you get fast. Then grouchiness sets in.
    Mar 2006
    3
    To answer a couple of questions:
    the motor doesnt' move. The references for x and y simply change and by a lot. Z axis does go to zero.
    By coincidence, I just checked the homing performance. Absolutley perfect for y and z, a couple of thousnaths occasional variance for x. Dont khnow why. I had to fiddle with the debounce to get x to work correctly. However, i noticed the reference problem long befor i even put the homing switches on, so it isn't that.
    Mar 2003
    35494
    Do you have one of the offsets turned on? G55,G56....??
    Gerry
    Mar 2006
    3
    Not that I know of, that is I didn't turn them on. I'm not sure but I think the numbers for x and y that appeared are the machine coordinates for the reference poiont I am trying to zero out. I need to replicate the error to verify that.
  1. Zeroing imported parts
    By an0n in forum Mastercam
    Last Post: 01-10-2007, 08:13 PM
  2. Zeroing the dials?
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 11-18-2006, 12:53 AM
  3. OK Zaxis Zeroing Technique - Benchtops/Mini/Bridgeports!
    By bill south in forum Benchtop Machines
    Last Post: 09-17-2006, 04:48 PM
  4. Question about Referencing and Zeroing.
    By redbaron in forum Mach Software (ArtSoft software)
    Last Post: 04-19-2005, 06:34 AM
  5. Poor results, help please!
    By Swede in forum Hard / High Speed Machining
    Last Post: 04-04-2004, 05:23 AM
