586,072 active members*
4,767 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Strange surface pattern in x axis only?
    Jul 2019
    24
    Hi not sure where to post this,
    I am experiencing a strange pattern when cutting only in the x axis direction, up/down milling doesn't matter.(see attached photos)
    The strange marks happen to be ~5mm intervals which happens to be the same pitch as my ballscrew...?
    I am using Linuxcnc + dmm servos.
    I have tried leaving the end bearing loose and loosing the nut attachment so it can move in case of any alignment error but made no difference.
    Note the endmill im using is not in good shape and is chipped but is no different with a brand new. Despite the avg finish it is very smooth.
    Any help would be great
    Ritzy
    Attached Thumbnails Attached Thumbnails 20200905_103158.jpg   20200905_103408.jpg
    Dec 2013
    5717
    Re: Strange surface pattern in x axis only?
    Bent ball screw maybe?
    Jim Dawson
    Sandy, Oregon, USA
    possibly a bent ballscrew as mentioned or the machined end for the bearing is off center
  1. Strange issue, laser tube burn pattern on test piece is a concentric ring.
    By garagefela in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-16-2016, 03:44 PM
  2. STRANGE PATTERN
    By MrRogue in forum Milltronics
    Last Post: 12-11-2015, 06:00 PM
  3. Extrude Cut Pattern to a contoured surface
    By Forrest C in forum Solidworks
    Last Post: 02-11-2015, 05:09 PM
  4. Crosshatch/Mesh pattern on casting surface...Why?
    By Splint in forum Casting Metals
    Last Post: 02-27-2007, 02:58 AM
  5. Strange cutting pattern
    By owhite in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2005, 05:48 PM
