588,178 active members*
4,881 visitors online*
Results 1 to 8 of 8
    Dec 2006
    3
    Stuck In Mm On Fanuc 18t, Help!
    I'm a new member, and I need a little help please.
    On the offset page shown below, my input unit
    for INCH got turned off on a Fanuc 18T lathe.
    I think there's a bit turn off somewhere in the parameters,
    that does not allow me to turn INCH back on.
    This page looks something like this:
    SETTING (HANDY)
    PARAMETER WRITE = 0 (0: DISABLE 1: ENABLE)
    TV CHECK = 0 (0: OFF 1: ON)
    PUNCH CODE = 1 (0: (0:EIO 1:ISO)
    INPUT UNIT = 0 (0: MM 1:INCH)
    ------ THIS LAST ONE ABOVE IS
    ------ NOT TURNING BACK ON.
    So my question is, does any one know whats preventing me
    from just typing in #(1) and reactavating INCH?
    Dec 2003
    24220
    Are you in MDI when changing the bit, I thought you could change it without the PWE bit being set, but you may have to, PWE should be on the Handy screen at the top, also check P0 bit #2 for a 1 (Inch mode).
    You may have to power down and up again to store it in memory.
    You may be able to change it with G code G20.
    Al.
    Albert E.
    Sep 2005
    767
    You should be able to key that bit in in MDI mode. Just move the cursur to it and enter "1" then press INPUT. The control must be in MDI mode, and the memory protect key switch must also be off.
    This bit should also change with the status of G20/21, so key in a short program with a "G20" command, run the program, and see if the bit has changed to "1" for INCH
    Dec 2006
    3
    Thanks guys for the reply's.
    I did have MDI on, I forgot to say that.
    I tried G20/G21, it alarmed (illegal G code) while in MM??????
    So I found the backup parameters on floppy, and loaded them
    in my computer, opened with microsoft works, printed just the
    9000 parameters.
    I compared the originals with what was in the machine, and near the
    top was (original 9920-00010000).
    The (machine 9920-00000000) was missing the above bit.
    When I turned it on, it allowed me to turn
    ---------INPUT UNIT = 1 (0: MM 1:INCH) back on to INCH.
    Thanks again for your reply's
    Sep 2005
    767
    I guess you've just discovered that inch-metric is an option on the Fanuc control. If you turn the option off, the control only has the ability to run in the same increment system as the ballscrews (in this case, metric). Running a machine with metric ballscrews in inch or inch ballscrews in metric requires the option. Since virtually every control out there has this option, no one thought to suggest this as the problem. Nice goin'
    Dec 2006
    3
    Quote Originally Posted by TEVAN View Post
    9000 parameters.
    9920-(00100000). THIS IS THE CORRECT BIT, JUST INCASE SOMEONE ELSE
    NEEDS THIS PARAMETER TURNED ON. I WAS ONE BIT OFF ON MY LAST POST.
    Mar 2007
    3
    On our Fanuc 18M we changed 1001.0 to 1 and the got the machine to change to Imperial from Metric.
    Mar 2003
    2932
    Quote Originally Posted by Dez View Post
    The original post was from 2006. I think maybe they got it running.
