Technical Specifications
Form Factor
Small tablet size, pen-based computer
Overall Dimensions
7.3" x 11.0" x 1.6"
185 mm x 279 mm x 40 mm
Weight (with battery pack)
3.5 lbs. (1.6 Kg)
Architecture
IBM PC-AT compatible
Microprocessor
AMD Am486 DX4, 100 MHz
8 KB On-Chip Cache
Integrated Math Coprocessor
System Memory
8 MB DRAM standard
Upgradeable to 12 MB, 16 MB, 24 MB
BIOS
512 KB Flash ROM
Expansion
One ATA Slot (Mass Storage)
Accepts Type III PCMCIA-ATA hard disk card or Type II/III solid-state flash card (SanDisk)
Two PCMCIA 2.1 Slots
Accepts two Type II PCMCIA cards or one Type III PCMCIA card
Display
DSTN Color LCD
Backlit, 8" (197 mm) diagonal
0.25 mm dot pitch
640 x 480 VGA resolution, 256 colors
Digitizer
Electromagnetic Digitizing Tablet
1016 points/inch resolution
133 points/second sampling rate
Interfaces
Keyboard (PS/2 style)
Parallel (ECP, Bi-directional)
VGA (simultaneous with LCD)
RS-232C Serial
IrDA (or Rx/Tx Serial with Port Replicator)
System Interface Port (for Port Replicator)
External Floppy Disk Drive
Mouse (only with Port Replicator)
Power
Lithium ion Battery Pack
Autosensing 100-240V, 50/60 Hz AC Adapter
Battery Life
3-6 Hours (application dependent)
Power Management
Save-To-Disk, Suspend and Standby Modes
Supports Intel and Microsoft APM 1.1
Options
Memory Expansion Modules
(4 MB, 8 MB, 16 MB)
PCMCIA ATA Hard Disk Cards
(260 MB and 340 MB)
PCMCIA Cards such as:
Fax/Data Modem, LAN, SanDisk, Solid-state Flash, and SRAM
Port Replicator
External 3.5" Floppy Disk Drive
Keyboard (low-power)
Auto Adapter (12-24 VDC input)
Dual Battery Charger
Bar Code Wand
Desk Stand
Hand Straps
Stylus Tether
Screen Protector
Slipcase
Harsh Environment Case
Keyboard Combo Case
AC Adapter (spare)
Lithium ion Battery Pack (spare)
Stylus Kit (spare)
Operating Systems
Windows 95 with Pen Services 2.0
MS-DOS 6.2 and Windows for Workgroups 3.11 with Pen Extensions 1.0
