Success controling 5-axis. Hot damm. This is fast and tight.
What I want to know is how to get dual axis readouts on the screen. Camsoft said I could do it but I have not found any info on this.
Please help if you know how.
I take it you want something custom that's not in the standard readout window.
The latest version of CNC pro has a huge upgrade in graphic and display options. They have a nice tutorial lesson plan to go through to see all the possibilities.
In general, put a READOUT command in timer.fil to create the variable you want to track. then update it to the screen. The design is only limited by your imagination.
Karl
machinestogo
This is a new feature in V17. We'll be glad to show you if you can send us your CBK file.
Congrats on your success
Tech Support
CamSoft Corp.
[email protected]
PH 951-674-8100
Fax 951-674-3110
PC Based CNC Control For The Machine Tool CNC Retrofit And CNC Controller OEM Market
Thanks for the help. It did work. The dual readout parameters were buried in a place I didn't think to look at.
By the way. You got my name wrong. I go by machines2go
