587,999 active members*
2,432 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Suggestions for low-voltage high-resolution servo
Results 1 to 15 of 15
    Nov 2015
    371
    I am working on a prototype that requires a single-axis servo system with very high accuracy. I don't need a lot of power or torque, the servo will turn a relatively light object just several degrees. I looked online but I couldn't find many options. Maybe I am not searching correctly. The application is very sensitive to vibrations so I cannot use a stepper.
    Could someone suggest a brand/model or simply point me in the right direction?
    These are the requirements:
    - Brushless
    - Low voltage
    - The drive should be able to work with Pulse(Step)/Direction signals
    - Very high PPR
    In previous discussions in this forum, I've read about motors (encoders) with 40000PPR or even more, however, I couldn't find even one.
    The closest thing I found so far are these:
    - ACM601V36-T
    - ACS806
    Could you recommend a better alternative?
    Mar 2003
    35538
    Re: Suggestions for low-voltage high-resolution servo
    How about a DMM with DYN2 drive.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2015
    371
    Thank you very much Gerry!
    I'll contact them for details.
    Sep 2010
    1765
    Kollmorgen.... over 3,000,000 counts per rev. Any lo voltage you want. Kollmorgen.com. akm motors with akd drive. Fastest update time digital drive on the market. Pm me if u want help deciding what u need.
    Sent from my SM-G900V using Tapatalk
    Nov 2015
    371
    Quote Originally Posted by mike_Kilroy View Post
    Thank you Mike! I sent you a message.
    Jan 2005
    15362
    Quote Originally Posted by Storen View Post
    - Brushless
    - Low voltage
    - Very high PPR
    - ACM601V36-T
    - ACS806
    DMM is your best choice for price on servo and drives with a high resolution Encoder there standard 16 Bit or you might be just in time for there new 32 Bit encoder soon to be released, most likely at IMTS show this month
    Mactec54
    Jan 2005
    15362
    What they have does not come close to standard Yaskawa Fanuc or DMM
    Mactec54
    Nov 2015
    371
    Do you know if Yaskawa and Fanuc offer servo drives that work with Pul/Dir signals?
    Jan 2005
    15362
    Yaskawa and Dmm does for sure, Fanuc no
    Mactec54
    Nov 2015
    371
    Which Yaskawa drive accepts Pul/Dir input?
    Sep 2010
    1765
    Haha. You're still up to making false and dumb comments I see.
    Jan 2005
    15362
    Sigma II and up to the latest would be the only Drives Motors to look at starting at SGDH series they use all methods for control so you have a choice and the Sigma II are standard with 17Bit encoder, and adjustable to what ever resolution you want to use, they are also very easy to get up and running, with this plug from CNC4PC you then only need a Ethernet cable to a Breakout Board for Step / Dir Control, I do have some of these new starting at 400w
    Mactec54
    Jan 2005
    15362
    The facts speak for themselves
    Mactec54
    Nov 2015
    371
    Interesting. Do you know if the signal-converter from CNC4PC would work with the more recent Yaskawa drives?
    Would it work with the single-axis SGD7S Sigma-7Siec for example?
    Jan 2005
    15362
    It is not a signal converter, it is just simplify the connection, I'm not sure if the sigma 7 have the same plug or pinouts but I could check, yes sigma5 and 7 are very nice
    Mactec54
  1. Low Voltage vs High Voltage Stepper motors?
    By Brian_M in forum Stepper Motors / Drives
    Last Post: 06-21-2017, 07:29 PM
  2. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  3. High voltage & high power servo drive design
    By Xerxes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-23-2008, 03:24 AM
  4. High Resolution Encoder Help
    By Donovan in forum Servo Motors / Drives
    Last Post: 02-13-2005, 04:05 PM
