I just recieved a SummaCut D60 but the previous owner could not find the dongle. Is it possible to even use this with out it? Can I cut vinyl directly from CorelDraw.
A vinyl cutter doesn't normally need a dongle to operate properly... the missing dongle probably refers to the software the previous owner used to run the cutter.... more than likely Flexi sign.
If you want to cut on your Summa direct from Corel you need something like CoCut... draw your graphics in corel, export to CoCut and use this to control your cutter.
CoCut is easy to find using Google and it's not that expensive.
I actually found a direct plug-in to use within Corel Draw12, it works great but I still haven't found how to do a simple shadows. Any help would be nice.
