603,316 active members*
2,880 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Super Mini Mill 2 Buzzing from Air filter/regulator
Results 1 to 5 of 5
    Apr 2008
    75
    I have a new Super Mini Mill 2 (less than a year old).
    After I run for 3 or 4 hours, a buzzing sound starts to come from the bottom of the air filter/regulator. The buzzing gets progressively louder, and I have to shut the mill off for several hours to get it to stop.
    If I put my finger under the bottom of the regulator, the air coming out feels moist. I don't have a dehumidifier (yet) on my air compressor.
    Any ideas?
    Nov 2007
    69
    is it the auto drain?
    Feb 2007
    498
    its the auto drain on the filter reg,maybe its dirty,my gets that way sometimes from dirty
    gunky water that runs thru it,the clear bowl should twist off,turn off the air first,than clean
    it all out and put back on,it that fails to work might have to replace the reg
    Jul 2005
    12177
    Quote Originally Posted by Gabe Newell View Post
    ...If I put my finger under the bottom of the regulator, the air coming out feels moist. I don't have a dehumidifier (yet) on my air compressor.
    Any ideas?
    It is the drain on the water trap doing its job. Carry on using wet air and you are headed for all the annoyance other people have described regarding sticky solenoid valves and tool changer malfunctions.
    Apr 2008
    75
    Thanks, all.
    I will clean the bowl and also get a dehumidifier.
  1. Super Mini Mill - decisions
    By TravisR100 in forum Haas Mills
    Last Post: 09-01-2009, 04:21 PM
  2. HELP!! Haas Super Mini Mill
    By CountBraden in forum Haas Mills
    Last Post: 07-07-2008, 12:20 AM
  3. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
  4. help with super mini mill please
    By daleman in forum Haas Mills
    Last Post: 08-14-2006, 08:32 PM
  5. part for super mini mill
    Last Post: 05-04-2006, 07:03 PM
