We have a Super MiniMill that is used with a pair of Kurt 688 vises or a Haas HRT210 rotary with a tailstock and rotating fixtures. The vises are bolted to a subplate with dowels for alignment on the table so they are heavy. We built a hoist with a L shaped base that bolts onto three of the machine levelling screws with a vertical column made from trailer hitch receiver tubing just to the right of the machine door. An articulating arm pivots on the top of some 2" x 2" x 1/8" HS tube sliding in the receiver tube and pushed up by long stroke jack (Fig 1). The vise subplate is unbolted from the machine table, the hoist swung in and attached to a bracket bolted to the subplate between the vises (Fig 2). This allows the vises to be lifted over the door sill (the real hard part when this is done by hand) then the hoist is lowered and the vises are swung under the controller where they stay when not in use (Figs 3 & 4). The rotary lives inside the machine enclosure hanging from a turnbuckle attached to the square tube that supports the controller. With the vises gone the machine table is moved over (Fig 5), the rotary dropped down onto its mounting plate, the turnbuckle disconnected and the rotary slid forward under two front clamps and against two setscrews used for alignment (Fig 6). Two setscrews and two clamps are installed in the back of the rotary everything is finally tightened and it is ready for mounting the fixtures and tailstock. Alignment repeatability is better than +/- 0.0005" parallel with the Y axis and rotary centerline position. Total changeover time 10 to 15 minutes.
