X3 and Super X3 are very similar. I posted my plans for my X3 conversion on my website (see sig line) - feel free to look them over and look in the photo gallery for how I fit the Z stepper back there. 425's will be fine on X and Y direct drive. On my Z I have a 640 with a 2.6:1 gear reduction making my Z about 1664 oz/in. You do need more force than the 425 - but I don't know exactly how much. I can make my Z stall if I want to. The power supply is on the small side - I run 52V and really should run higher.
Oops - 2mm pitch...you're running the ACME leadscrews? If so you won't have speed, and the efficiency of the screws is going to sap a lot of the power. Not sure what to recommend. Ballscrews were a definite for me from the get go. Still - the concept of the motor mounts on my plans could be adapted to the stock ACME screws, you'll just need to do some measuring to locate the centerlines.
Every day is a learning process, whether you remember yesterday or not is the hard part.
www.distinctperspectives.com
