Or for another idea, scribe a line down the edge of the pipe lengthwise. Drill holes every 6" or so, and tap for 1/4" NFT. Drill corosponding holes in the base of the machine, and insert a bolt. The bolt must have no shoulder. Put two hex nuts on the bolt, then thread into the pipe. Set the two ends to their height, then tighten the nuts to the pipe end, and the base end to lock in place. Go down the line and do this at every bolt, and you have a mounting system that is not only solid, but is infinately adjustable for absolutely true ways! Length is also not an issue, as the bolts run the entire length of the ways.
Stop talking about it and do it already!!!!!
