603,900 active members*
2,846 visitors online*
Results 1 to 8 of 8
    Dec 2004
    27
    Question Support for linear guide
    Does anyone know of a good (and inexpensive) method of supporting rod type linear guides. Preferably with as little drilling in the guides as possible as I do not have easy acsess to high presision drill/mill. The guides are 25mm in diameter and they span 3 m. The gantry that will ride them is weighing ca 50kg.
    Dec 2004
    27
    I have just seen the light!
    http://www.cnczone.com/forums/showthread.php?t=8133 :cheers:
    Dec 2004
    27
    :withstupi
    Sorry, I take that back... Jumped co conclusion before examining design...
    Question still stands...
    Sep 2004
    85
    I haven't played around much with rod-type guides, but here's some thoughts...
    If vertical deflection is the only concern, (bows under weight of machine), you could arrange some bolts as setscrews. Depending on the clearance your linear bearings have for supports, you could grind a depression in the head of the screws that has the same radius (or close) as the rod and then use two nuts on either side of a bracket to adjust the height.
    Sep 2004
    85
    Quickie sketch...
    Dec 2004
    27
    Quote Originally Posted by nuplowboy
    Yes, that might work. Thanks!
    Sep 2003
    226
    This was my solution...the10 ft (3 m ) pipe-track is bolted onto a channel. So far so good.....
    Dec 2004
    27
    Clever, but it is a solid rod and not a pipe. But the U-beam solution might be worth examining further. God input, thanks!
  1. Offering my services and support to CNCzone!
    By AjaxCNC in forum Centroid CNC Control Products
    Last Post: 10-06-2018, 08:15 PM
  2. shaft support
    By smarbaga in forum Mechanical Calculations/Engineering Design
    Last Post: 04-17-2005, 02:58 AM
  3. Stepper motor as end support
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-15-2004, 02:48 PM
