587,223 active members*
3,061 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Surfcam and Subroutines
    Apr 2010
    Has anyone programmed Surfcam that has subroutines in them? I came from a shop that did lots prototype parts and now Im in a production shop. I need help trying to figure this out.
    Jul 2007
    148
    Smile
    There are posts in the /PostLib/MPost folder that you can try using. I know for sure they have a Fanuc one in there as I use that one occasionally. I use to use Virtual Gibbs and I feel that Gibbs handled subroutines in a much nicer way. After you program your part, there is also the option of using the transform operation technique. In your operations manager, there is a box next to the verify button. This has one option called rectangular array. It will lay out a bunch of parts in a grid format for you. I don't like this method much because it makes the programs really huge and if you have a controller with limited memory, it can be a problem, but it does work for some applications.
    Hopefully this will help you a little.
    May 2007
    71
    There are two way to do that in SURFCAM system:
    1. Use the Operation Manager --> Transform Operation and yourcould find a lot of method you could use. SURFCAM is the fisrt one CAM system has all the functions.
    2. Use the MPost(more easier) to write a post you need. It could output the G54 -- G59, M98 subroutines, you aslo could output the macro call, or L/N code subrountines
  1. Edgecam Subroutines
    By John Holmes in forum EdgeCam
    Last Post: 02-05-2013, 05:45 PM
  2. with subroutines
    By Thad Swarfburn in forum G-Code Programing
    Last Post: 06-25-2009, 02:37 AM
  3. Arguments for Subroutines (G65)
    By theragust in forum Milltronics
    Last Post: 10-17-2007, 04:04 PM
  4. EMC and Subroutines?
    By watchman in forum LinuxCNC (formerly EMC2)
    Last Post: 06-17-2007, 08:30 PM
  5. Oi subroutines help
    By mishikwest in forum Fanuc
    Last Post: 08-01-2006, 11:17 PM
