588,191 active members*
7,523 visitors online*
IndustryArena Forum > CAM Software > Surfcam > SurfCAM and Tombstones
    Sep 2006
    74
    Anybody done any tombstone parts with SurfCAM? I am looking for tips or examples. I will be milling on a Haas, type yet to be determined, but I am trying to get a start on setup.
    I assume it's all about CView and construction coordinate setup that makes the system work.
    Thanks,
    jetpig1
    Dec 2009
    80
    Hi, do you have a horizontal MC and want to machine multiple parts around the table? If that's the case you can program the first part and then use the "transform operation" function in the operations manager to machine the other parts. Does your postprocessor support B-axis indexing?
    Apr 2010
    tombstones
    I do all the time...it is time consuming but yes you are right c-views. you must set up all your views and label them. also make sure you put in your work offsets if you use them. I hope this is sum-what helpful. it does get a bit tricky when all you cutter path is displayed.
  1. Programming Parts On Tombstones
    By thebowman in forum Esprit
    Last Post: 05-13-2018, 03:14 PM
  2. New tombstones...
    By Sump Cleaner in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-06-2008, 03:34 AM
  3. What is Surfcam SE?
    By moldcore in forum Surfcam
    Last Post: 03-22-2007, 04:53 PM
  4. my hobby laser cutter - tombstones
    By KTP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-10-2006, 02:51 AM
  5. Surfcam help
    By jamesr in forum Uncategorised CAM Discussion
    Last Post: 12-13-2005, 02:10 PM
