587,822 active members*
2,928 visitors online*
IndustryArena Forum > CAM Software > Surfcam > SurfCam V4 and Windows 7
Results 1 to 5 of 5
    Nov 2009
    93
    I am setting up a new system and I'm trying to load SurfCam Velocity 4 on a computer with the Windows 7 64bit OS.
    It gets to loading translators and then it seems to come to a stop, after about a half hour I run out of patience.
    I need to know if Surfcam V4 is compatible with Win7 64 bit, do I need to go to Win7 32bit or Win XP compatible mode.
    If you have any information please let me know...
    Apr 2003
    637
    For kicks I loaded SC 4 build 248 on my 64 bit, win 7, laptop last night. No problems as far as I could tell. There was some error pop ups about compatibility issues that I let Windows correct right at the beginning. It did take about 20 minutes to install from the CD.
    Nov 2009
    93
    Red face
    I got it loaded on Win 7, 64 but it wouldn't run. The computer is a Apple MacPro with 16 virtual processors, I'm not sure if that matters.
    I found out from a reliable source that SC support doesn't recommend 64 bit OS's. Totally frustrated, I installed Win7 32bit and voila it works like a champ. SC doesn't expect to have a working 64 bit version to test until next year and with the world ending in Dec 2012 it may be too late...
    BTW, that fully looaded MacPro with the LED cinema display and high end video card is really quite stunning. It exceeds all of my expectations, who needs 64 bit..?
    Thanks for your input
    Mar 2011
    programer
    I have Viper 950 cnc , how You load program to machine, how you comvert metric to inch, because i make program anh load in ,then machine run by metric, so how you fix this
    thank you
    Nov 2009
    93
    The questions you ask vary from machine to machine. Best advice I can offer you is to read the machine manuals...
  1. SurfCam 6.1 with Windows 7???
    By lkenney in forum Surfcam
    Last Post: 06-03-2012, 10:17 PM
  2. windows 7
    By badassdevil in forum Mastercam
    Last Post: 05-14-2010, 09:19 PM
  3. CCS for windows, please.
    By samaniegoh in forum Controller & Computer Solutions
    Last Post: 04-12-2010, 05:53 AM
  4. surfcam and windows vista?
    By dcrblazer in forum Surfcam
    Last Post: 03-08-2007, 12:30 AM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
