Alarm SV013 on X and Z Axis.
Machine: Mori Sieki Junior vertical mill,circa 1985 with Fanuc 10M controller.
We are a new shop with existing,in place machines that came with the place. This machine obviously had issues as the instructions on how to over ride normal start-up checks are hand written in front of the operator manual. I believe it's press - and . while powering up and bypass normal reference check,rehome etc...
But the bigger issue with Junior is while checking the travel limits to better visualize the fixtures we can utilize...it sat for a few minutes within travel limits,no alarms...Came back and we have the SV013 alarms.
Ladder shows the servos are not powering up causing the alarm. Checked the terminals for the servos. They are supposed to read 100 volts AC and only show 60 volts AC.
We have an identical model and it checks as it should...
Not sure how a machine setting within stroke limits can suddenly loose 2 servos at the same time? The machine cabinets have oil and residue inside,including board cabinet...
Any one have ideas on how bad this really is? Thank you.
