603,939 active members*
3,160 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > sweo ac vector control problem
Results 1 to 6 of 6
    Feb 2006
    my sweo ac vector control (fadal vmc15 year 1994) has a problem.
    It break the 2A fuse on the snubber card especially when i go in hi speed (over 2000 rpm).
    I have also noticed that the 27 ohm regen resistance almost go on fire when the spindle run
    I suppose that the problem could be : or a failure of the big capacitor , or the scr that must to shut-off this part of circuit when the motor run ,or the drive of the scr , or at least a problem of the power transistor
    Any suggestion ?
    Thank to any one that can help me and sorry for my poor language
    Apr 2005
    109
    I think it came from the big transistor the best way it will be
    to replace the baldor
    ask MELZI in EUROMECANICA to help you meby also by repair it
    is a good tecnition
    Mar 2006
    8
    Hi. We have a problem with a VMC15 the SWEODRIVE displays OC error when changing speeds.
    Anyone know the Parameter setting for the drives. or known problems
    Any help would be great.
    Machine been down for 5 days now.
    Knowone in the UK has heard of a Sweodrive !
    Mar 2003
    900
    Check with Brenden at Yamasan London. They repair Fadal machine all the time.
    Neal
    Mar 2006
    8
    Cool
    Thanks.
    Been advised to buy a new Control.
    Ordered one, today.
    Would like to know a bit more about them.
    Or find a Good repair shop with lots of experience as we have another machine with the same drive , bought at the same time.
    Mar 2003
    900
    Yamasan used to be the Distributor for Fadal in the UK. The current Distributor is Cross Hueller.
    NEal
