I usually move the X Axis in Rapid leaving the stock material (Z Axis) in the last position where it left off.
BTW: Write a Sub-Program for tool change positions so you can save yourself some confusion. Also when you call a tool on one Turret call the next tool on the other Turret. This helps to save a little cycle time.
O4130;
M8;
S2500 M3;
G0 G40 G80 G99 Y1.5 T0 M11;
G110 T0;
G100 C6.6;
G300 Z.75;
M10;
G50 Z-.01;
G0 X1.5 Z-.02 T0 M18;
M1;
N1(FACE);
T505 S6500 M13;
G0 X.4 Z0;
G1 X-.005 F.001;
G0 X.4 Z-.01;
X1.5 T0;
N2(SPOT DRILL 3/8 DIA. HSS);
T1111 S1500 M13;
G0 Z-.02;
Y0;
G1 Z.13 F.0015;
G4 U.05;
G0 Z-.05;
Y1.5 T0;
N3(DRILL 1/8 DIA. 135SPT COB STUB);
T1212 S1500 M13;
G0 Z-.02;
Y0;
G1 Z.335 F.0015;
G4 U.05;
G0 Z-.05;
Y1.5 T0;
N4(BORE .11 DIA. TRUEMADE COATED);
T1313 S2000 M13;
G0 Y.6 Z-.05;
G1 Y.339 Z-.015 F.005;
Y.127 Z.091 F.00025;
Z.285 F.0005;
Y.125;
G0 Z-.05;
Y1.5 T0;
N5(FACE/CH/TURN/SANDVIK CRMT);
T051505 S6500 M13;
G0 X.4 Z0;
G1 X.275 F.0008;
X.329 F.0015;
X.339 Z.005 F.0003;
U-.0005 Z.425 F.0005;
X.355 Z.4332 F.0003;
G0 X1.5 T0;
N6(R-GROOVE .058W THINBIT);
T140614 S1800 M13;
G0 Y.4 Z.3142;
G1 Y.24 F.0005;
Y.349 F.01;
G0 Z.308;
G1 Y.24 F.0005;
Y.349 F.01;
G0 Z.32;
G1 Y.24 F.0005;
Y.35 F.01;
G0 Y1.5 T0;
N7(F-GROOVE .069W CRMT ROBINSON);
T150615 S6000 M14;
G0 Y.349 Z.304;
G4 U.05;
G1Y.329 Z.314 F.0003;
Y.219;
Z.325;
Y.329;
Y.349 Z.335 F.0003;
G0 Y1.5 T0 M5;
N8(SLOT SAW 1.25 DIA. .02 WIDE 36T);
/T011501 M8;
/G50 A0;
/A.9;
/M70;
/M117(750 RPM);
/M114(CCW);
/M10000(0 DEGREES);
/G0 X.75 Z-.05;
/X0;
/G98 G1 Z.26 F15.0;
/G4 U.05;
/G1 A-.4 F3.5;
/Z-.05 F25.0;
/M10900(90 DEGREES);
/G0 A.8;
/G1 Z.26 F15.0;
/G4 U.05;
/G1 A-.4 F3.5;
/Z-.05 F25.0;
/G99 X.75 M115;
G0 X1.5 T0 M71;
N9(RE-BORE);
T130513 S2000 M13;
G0 Y.6 Z-.05;
Z.285 Z.0005;
Y.125;
G0 Z-.05;
Y1.5 T0;
N10(RE-GROOVE);
T150515 S6500 M14;
G0 Y.349 Z.304;
G4 U1.0;
G1 Y.329 Z.314 F.0003;
Y.219;
Z.325;
Y.329;
Y.349 Z.335 F.0003;
G0 Y1.5 T0;
N11(RE-FACE/CH/TURN);
T051505 S6500 M13;
G0 X.4 Z0;
G1 X.275 F.0008
X.329 F.0015;
X.339 Z.005 F.0003;
G0 X1.5 T0;
N12 (CH/BACK/CUT-OFF .06W THINBIT/CRMT);
T061506 S3500 M13;>>>>>>>This calls both sides at the same time
G0 Z.4;
X.4;
G1 X.2 F.0005;
X.349 F.003;
Z.39;
X.329 Z.4 F.0003;
X-.035 M17;
M18;
M95;
/M98 P9800;
M96;
M97;
M30;
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
