603,344 active members*
3,205 visitors online*
Results 1 to 6 of 6
    Jan 2014
    3
    swiss program of long parts
    We just purchased a Citizen A20 VII we program with cnc wizard. The main spindle travel is 5 inches, I need to program a part 6.03 inches long. Any help would be greatly appreciated.
    Feb 2005
    303
    Re: swiss program of long parts
    Maybe I'm missing something, but can't you just re-chuck after finishing the first half of the part?
    Jan 2014
    3
    Yes. This is our first swiss machine and we are still learning it. Here is part of my program maybe I am missing something.
    # 530 is steel dia.
    (FACE & TURN)
    M3 S1=2500
    T200
    G0 X[#530+0.025] Z0 T2
    G1 X-.035 F.003
    G0 Z-0.025
    G0 X.510 Z0
    G1 Z4.0 F.003
    X[#530]
    W0.025
    G0 X[#530+0.025]
    M5 (STOP MAIN SPINDLE)
    G4 U.5 (DWELL)
    M7 (OPEN MAIN COLLET)
    G4 U.5 (DWELL)
    G98 G1 W-2.0 F100.
    G50 W2.00
    M6 (CLOSE COLLEET)
    G4 U.5 (DWELL)
    G99 M3 S1=2500
    G0Z3.99 (.010 SHORT OF WHERE YOU LEFT OFF)
    G1 X.510 F.003
    Z5.822
    X.620
    Z.6.05
    X[#530]
    W0.025
    G0 X[#530+0.025]
    Feb 2005
    303
    I don't have a Meldas control available at the moment to verify, but the G1W / G50W lines should take care of it... Is it not working like this?
    Sep 2011
    261
    Your code looks fine with 1 exception. You need something to hold the stock in place while the main collet is open. If you set your guide bushing tight enough to hold the stock in place, that may work, but I would consider that dangerous because if the bar hits a low spot and the GB is no longer tight enough to hold the stock, the bar feeder could push it out and you could whip the bar in the machine, crash the sub, or generally have length problems.
    So, your code is fine, but just needs the sub to approach and chuck on the part before you open the main collet, then open it after the regrip or spindle sync it.
    Here's what I would do.
    M3 S1=2500
    T200
    G1 X-.035 F.003
    G0 Z-0.025
    G0 X.510 Z0
    G1 Z4.0 F.003
    X[#530]
    W0.025
    G0 X[#530+0.025]
    G4 U.5 (DWELL)
    G650 (superimpose z2 on z1)
    !1!2 L650 (wait for sub to be in place)
    G4 U.5 (DWELL)
    G98 G1 W-2.0 F100.
    G50 W2.00
    M6 (CLOSE COLLEET)
    G4 U.5 (DWELL)
    M3S1=0M24S2=0 (turn spindles on at 0 rpm)
    G114.1H1D-2 (Spindle sync at 0 rpm. NOTE if you have an R value on this line this WILL NOT work)
    (alternately, you could just open the Sub (M16) and fire up the main spindle and not sync, but I think spindle sync from a stop is a cool trick, so I do it all the time and it works well)
    G99 S1=2500
    G1 X.510 F.003
    Z5.822
    X.620
    Z.6.05
    X[#530]
    W0.025
    G0 X[#530+0.025]
    Then in $2:
    G650 (Superimpose on)
    M16 (Open sub. last part should already be ejected)
    G0 Z-.3 (rapid to face)
    G1 G98 Z2. F120. (feed on some amount. I chose 2" for no particular reason)
    M15 (close collet)
    !1!2L650 (sub is in place and ready for main to regrip)
    Then right before cutoff, you'd probably want to move the sub up closer.
    $1
    !1!2L1000
    !1!2L1001
    (...cutoff)
    $2
    !1!2L1000
    M16 (Open)
    G1G98Z5.6 F120. (move up) (or z5.1 if you're using a .500" extended nose pickoff)
    M15 (close)
    !1!2L1001 (done)
    CNC Product Manager / Training Consultant
    Jan 2014
    3
    I will give it a try.
  1. Long threads on swiss
    By ChrisW in forum CNC Swiss Screw Machines
    Last Post: 01-22-2013, 06:06 PM
  2. Stainless Steel Parts - CNC Swiss
    By Hale in forum North America RFQ's
    Last Post: 10-07-2012, 02:40 PM
  3. Swiss Machine Parts
    By emagray in forum North America RFQ's
    Last Post: 05-02-2012, 01:01 PM
  4. Need help writing program for Citizen E2-32 for long parts
    By gizmo_454 in forum CNC Swiss Screw Machines
    Last Post: 12-16-2011, 07:17 PM
  5. Replies: 15
    Last Post: 04-14-2011, 05:33 PM
