588,685 active members*
6,283 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > SX3 -- Can't get the bed to slide off~~
Results 1 to 6 of 6
    Mar 2007
    215
    Hello~
    I just got my mill early last week... I haven't had much time until now to start cleaning it..
    So, I downloaded the "Introduction_to_your_machine.pdf"... and followed the instructions... upto page 3... "Using your superhuman strenght..."
    The motor mounting plate won't slide away from the bed... The dowel pins must be in too tight... When I pull on the table, the stepper and screw spins...
    If remove the stepper and then the bearing... I don't think it will slide off to the left as it will catch on the bottom... And it wornt slide of the to the left... I guess my only choice is to release the preload on the bearing and then slide the table off the right side...
    Any suggestions ??
    Thanks,
    Michael
    Oct 2006
    975
    Hi Michael,
    I think it would be better to try and pry off the motor mtg. plate than to remove the table by other means. Even if the dowels are tight I would think the plate could be pried off begining with a very thin wedge like a sturdy putty knife and then proceed with something thicker and even a pry bar until it comes off the dowel pins. Just an idea, and I hope you are able to remove it and finish the clean-up process without too much extra effort.
    Best regards,
    Regards,
    Wes
    Mar 2007
    215
    Good idea!
    I have a couple of putty knifes handy, so I'll give that a try ...
    I already spayed some wd40 on it last week... but there isn't even a hair betwen the two pieces... not sure if a putty knife will even get in there...
    thanks,
    Michael
    Mar 2007
    215
    Woot~~
    That worked great, thanks!
    My drywall knife isn't much good for drywall anymore.... it chipped a bit, will have to grind it...
    I had to do both the X and the Y like that...
    Now to do the spindle mod, I think I might need a puller to get that small sproket off...
    Thanks,
    Michael
    Jan 2007
    12
    Quote Originally Posted by krazatchu View Post
    I ended up using a loooong punch under the table to tap it off. I have not changed gears on my spindle yet so let us know how that goes.
    Mar 2007
    215
    Hey~~ the pulley change went without a problem... the pulley slid off with a tiny bit of prying ...
    The bolt that was in the bag with the spacers for the new pulley was much too long, so I used the original spacer and philips screw...
  1. THK slide bearing
    By Bill Davis in forum Mechanical Calculations/Engineering Design
    Last Post: 08-27-2006, 12:31 AM
  2. cross slide
    By nantz in forum Benchtop Machines
    Last Post: 07-13-2006, 12:09 AM
  3. Air slide question
    By 2muchstuff in forum Linear and Rotary Motion
    Last Post: 03-09-2006, 11:08 PM
  4. misumi slide
    By Felipe in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2005, 02:40 PM
  5. Corian as a slide?
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 04-27-2004, 01:44 PM
